How many Watts for PSU
ribpeal
45
Any help would be appreciated! :) These are the specs:
SAPPHIRE Vapor-X R9 270X (GPU)
ASUS A88X-PLUS (Mobo)
AMD A8-7600 - 3.1GHz, Quad Core (CPU)
Corsair Vengeance 2x8GB DDR3 (RAM)
WD Mainstream 1TB 7200RPM (HDD)
ASUS DRW-24F1SR (DVD-RW Optical Drive)
Agreed on staying away from the CX series.
Jonnyguru is the authority on PSU testing. He grades the CX lineup as a tier 6 of 9 tiers. There are many better PSUs for just a few dollars more. Really worth it.
Something like this would be great in your system:
XFX TS 550W - $52.99
http://pcpartpicker.com/part/xfx-power-supply-xfxts550w
It's made by Seasonic, one of the best OEM makers in the industry. Very high quality PSU.
500w would suffice, however better to invest in a bigger PSU so you'll be able to reuse it when you upgrade your video card (or going Crossfire/SLI), so I'd say at least a 650-750w PSU, make sure you get one that is 80+ Bronze Certified with 40A+@12V rail from a known brand like Seasonic, Antec, Superflower, EVGA, OCZ or Corsair (avoid it's CX series).
