how many watts of power does a typical PSU use by itself?
train_wreck
26
trying to get the power down in my home-built router PC, and was curious, how much power does a typical PSU draw, in watts, if it's just powered on with nothing plugged into it? (i.e., if you plug it into the wall and then short circuit cables 4 & 5 on the 24-pin connector). in particular, i'm looking into a Seasonic SS-400FL2, any ideas on that?
The amount of power the power supply uses by itself is not something you worry about when building a PC but the maximum is usually around 4~18 watts from the fan use and that is the absolute maximum.
That would be the same for that Seasonic PSU.
depends on whats connected to a pc and how efficient the psu is. with 80+ platinum your psu will only waste a maximum of around 11% of its intake. if the pc is idle it usually alot less than 80 watts depending on gpu and cpu usage and efficiency.
very hard to say really, although your best bet is a meter like a kill a watt will give you an accurate reading
thanks for the info folks. came in the mail today, and borrowed a buddy of mine's kill-a-watt. the jonnyguru site was pretty spot on, it's about .5-1W. the entire system uses ~22W idle, ~28 during intense VPN transfers.
appreciate the info all
