How many Watts Should power This?
Alexis92
330
Well i don't really know what PSU to get, can someone help me please? i don't know if i should get less watts for it or more it really confuses me, thanks.
Specs :
Processor
Intel Core i5-6600K
Motherboard
MSI Z170A PC Mate
Graphics Card
Sapphire NITRO R9-390 Tri-X OC 8GB
Memory
GSkill Ripjaws V 8GB Dual DDR4 2400
Hard Drive
Seagate 2TB 7200rpm
CPU Cooler
Cooler Master Seidon 120V
Power Supply
Corsair CS750M
Fans x4
DeepCool XFAN 120mm Fan
Already more than enough wattage the PSU has, so doesn't matter if it is gold or bronze, always look for the quality of the unit.
The PSU i suggested is Tier 1 Quality PSU / TOP Quality PSU.
There are already crap units having gold efficiency.
That being said, spending extra for 850w or seasonic G is not worth it over the m12ii 750w.
the one thats on the list , is it a good PSU? or do i have to pick something else?
No it's not good, it's just an OK unit. If you don't have any PSU yet,don't go with CS, get the G2 750W for just 79$, a much better unit.
well i can't buy from NCIX or Newegg becuase i'm not from the US im from Philippines and its very hard to find a shop that sells parts but here's the website where i'm buying parts from.
http://dynaquestpc.com/product-category/components/power-supply-psu/power-supply-psu-700w-900w/?orderby=price-desc
my budget is P 5,400 or $115
well isn't the gold ones better than bronze? also how about the Seasonic M12II-850 or the Seasonic G-750
also is the seasonic better than the cs that i was going to have?
Seasonic and Super Flower are the best on the market for power supplies, much better price/performance ratio than Corsair and other brands.
So theres your answer, the Seasonic is miles better. Review here:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=356
Don't even bother looking at efficiency rates like Gold or bronze. They're meaningless and are one of the least important stats to be looked at.
Much better. As for Seasonic, they always make good PSUs.
last question, sorry for this i just don't want my pc to become crap.
thanks i'm going to get seasonic now and is 750 watts enough for oc?
