[SOLVED] How much better is duel fan vs single fan?
Single fan cards like the 1050Ti are perfectly fine, unless you plan to overclock or want higher boost clocks its fine.
No, that specific card you linked does not need external power.
No, your intel graphics will be disabled automatically when you plug in the GPU. You also want to leave them installed in case you ever have an issue and need to boot back to the intel graphics.
Reactions: garrslayer
thanks so much!
