How much Difference between DDR4 64GB vs 32GB?
MaqDrew
51
I'm interested about 3d modeling & rendering including heavy multitasking........ about CGI/FVX by Autodesk entertainment suit and Adobe suite.........
My target spec is:
processor: i75960X
gpu: GTX 1080
mobo: asus SABERTOOTH X99
but fact is how much do I need (DDR4 ) the ram ....... 64GB or 32GB....... and how much difference will affect to my profession???
32GB vs 64GB has zero impact on performance unless you need it.
Nobody can tell you which you are going to need before you actually start doing the work you need.
If you get 32GB and thats enough, the 64GB will not benefit you at all.
If you are running 32GB and you keep using all of it, then 64GB will help with performance. We cant tell you what youre going to use.
I have not budget problem......... I can spent money...... for my highest performance ..........
Do I need 64GB for Maximum performance......... with heavily multitasking .......... or not?
may be 32gb maximum will be use .......and rest are will be not use......... in that case my money is totally waste.......
i'm doing 64 just cus. it actually cost less than the 32gb i in stalled in my last build. if you have the money, just throw it in there
