5 5dn Honorable Sep 22, 2013 12 0 10,510 Jun 16, 2014 #1 Dear Forumers, I have a tower with two possible settings for, I believe, the external fans. My question is: How much difference could setting it to the higher setting make for performance? (generally) Thanks, 5DN.
Solution Gam3r01 Jun 16, 2014 Case fans it dosent matter much, most are single speed anyway. For heatsink and radiators higher speeds can drop temps up to 10C depending on cooler, config, fans, and temps.
Gam3r01 Titan Jan 12, 2013 25,414 973 115,440 Jun 16, 2014 Solution #2 Case fans it dosent matter much, most are single speed anyway. For heatsink and radiators higher speeds can drop temps up to 10C depending on cooler, config, fans, and temps. Upvote 0 Downvote Solution
