It sadly looks like the NH-D15 cooler will be 1 mm overhanging the top x16 PCIe Slot, on the Supermicro X10SRA [xeon 2011v3] Motherboard.
If I loose this it means in the future there will be no slot to take a USB3.1 card.
Or instead of running it in:- x16, x16, Empty, x8 mode. I could run a x16, x8, x8, x8 configuration. Sadly the first x16 slot is lost.
Amazing the designer didn't suss that eh! Why put your only dedicated Gen 3 x16 [directly connected to the CPU] Slot so near the CPU!!
Most importantly, it would mean in the future, when an USB 3.1 Card Reader comes out [which I need for Photography jobs] - I would have to downgrade the GPU to a x8 slot. 🙁
So the real question is do these Nvidia GTX 980 or 970's really need all the channels in a x16 slot ( electrical lanes).?
Note the x16 and in the future x8 slot proposed for the GPU are both Gen3.0 and both go directly to the CPU.
I did read somewhere that there was only 1% difference in fps beteen using a x16 or a x8 Gen 3.0 slot.
I expected a lot more difference.
Sadly they think rotating the cooler 90 degrees will allow it to clear the PCIe slot but the cooling pipes will then hit the memory!
Any real world advice - appreciated.
Note the main use is Editing extrely large still photos 160MB per image files, say 800 images taken in a full day's shoot. And in the future 4K short 10 minute videos. Single monitor usage.
