A ankitsarkar600 Reputable Apr 19, 2014 10 0 4,510 Apr 19, 2014 #1 how much fps can i get if i crossfirex the XFX R9 270A DD 2 GB DDR5 Graphics Card with the amd a10 7850k s igpu
Solution I I ivanjacob Apr 19, 2014 You can't crossfire r9 series with apus. If you want to you should get an r7 card. But you're better of just buying the 270 and using the apu for hsa.
I ivanjacob Honorable Jan 3, 2014 156 0 10,760 Apr 19, 2014 Solution #2 You can't crossfire r9 series with apus. If you want to you should get an r7 card. But you're better of just buying the 270 and using the apu for hsa. Upvote 0 Downvote Solution
