Question How much FPS / how well would it be when it runs Roblox?
Fatblabs
326
15
4,695
CASe: Apevia Genesis ATX Mid-Tower W/ tempered glass windows + 4x 120mm RGB fans (White Color)
CPU: Intel® Core™ Processor i5-11600KF 6/12 3.90GHz [Turbo 4.9GHz] 12MB Cache LGA1200 [w/o Integrated Graphic]
CS_FAN: Default case fans
FAN: CyberPowerPC DEEPCOOL Castle 240EX ARGB 240mm AIO Liquid CPU Cooling System w/ Copper Cold Plate (2 x Standard 120MM Fans)
HDD: 1TB WD Blue SN550 Series PCIe NVMe M.2 SSD - Seq R/W: Up to 2400/1950 MB/s, Rnd R/W up to 410/405k (Single Drive)
IUSB: Built-in USB Ports (Based on motherboard and case selection)
MEMORY: 16GB (8GBx2) DDR4/3200MHz Memory (Team T-Force Delta RGB)
MOPAD: CyberPowerPC FPS Gaming Mouse Pad [free] (Large 14x12 Inches)
MOTHERBOARD: ASUS PRIME Z590-V ATX, ARGB, 1GbE LAN, 2 PCIe x16, 3 PCIe x1, 4 SATA3, 3x M.2 SATA/PCIe
MOUSE: Cooler Master MM710 Honeycomb Ultralight 16000 DPI Optical Sensor Gaming Mouse with Ultraweave Cable (GLOSSY BLACK)
KEYBOARD: CYBERPOWERPC Skorpion K2 RGB Mechanical Gaming Keyboard [+9] (Black (Linear))
NETWORK: Onboard Gigabit LAN Network
POWERSUPPLY: 600 Watts - EVGA 600Watts 80 Plus Gold high-efficient Power Supply
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: [Extra 2 Weeks Lead Time] GeForce RTX™ 3060 12GB GDDR6 Video Card (Ampere) [VR Ready] (Single Card)
Uh
That thing contains a 3060
That's overkill for Roblox, if your plan is to play Roblox then that computer isn't worth it as it will cost at least $2000.
If you really want it to run it on that, it could run it at maximum graphics at 60FPS though.
You can build a computer that can run minimum at 60fps for just $600.
Reactions: Fatblabs
Uh
No lol I was looking for max 240-300 FPS plus recording Lols. There’s an FPS unlocker for it
Uh
No I paid 1460 or something with out tax and shipping for everything
Uh
I got a good discount on it
