i ordered a new laptop with
I5-430m
8gb Kingston ram
Nvidia geforce GT 840m 2gb
How much fps will on get on minecraft?
G
Guest
Travis Sleith :
But I'm not going to use shaders
Yes, and with shaders you should get something around 40 to 60 FPS. Won't be stable though. You'll have a lot of FPS fluctuation.
EDIT: I read your post wrong. Without shaders, you should have something like 90-120 FPS.
69.6 if you remove shaders. You will be probably ok.
I did some math here, and it fell on the 420.69 line here. I don't feel like your FPS calculator is up to date.
Go in your BIOS and select change motherboard. Your FPS calculator should now work properly.
I don't think minecraft is a game worth mentioning as far as graphics performance goes. You will be fine. Even if your pc can run 50-400 fps you will be able to play and have a good time trolling.
