How much FPS would i get with these specs? (Building PC)
Nik42_
Commendable
Jun 28, 2016
8
So im looking for how much fps i would get on high to low settings on these games with the following specs :)
CSGO
Fallout 4
GTA 5
Gmod
Skyrim (With texture mods)
Specs :
CPU - Intel® Core™i5 Quad Core Processor i5-6600 (3.3GHz) 6MB Cache
Motherboard - ASUS® H110M-D D3: Micro-ATX, LG1151, USB 3.0, SATA 6GBs
GPU - 4GB NVIDIA GEFORCE GTX 960 - DVI, HDMI, 3 x DP - 3D Vision Ready
RAM - 8GB Kingston DUAL-DDR3 1600MHz (1 x 8GB)
Hard drive (might as well include it) 1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
If you could tell me an estimate on how much fps i would get on the games i listed with high and low settings i would highly appriciate your help! Thank you!
If you have not bought anything yet, don't. Save some money and go with the i5 6500. The 6600 isn't worth the added cost. Also, you should be using a DDR4 based system. The RX 480 is going to be released tomorrow. Pricing will be similar to that 960, but if the performance claims are true, it is going to be closer to a 970, in performance.
