Question How much gb ssd do I need in my system
Apr 3, 2019
So I want to change my hdd in data C with Adata Su800 Ssd. The problem is how much gb do I need on my ssd. And I doesn't place a game in data C maybe just a bit of game. And my Data c is usually contain picture and other things. And Im using win 10
I wouldn’t go below 500 GB and only upwards from there
Alright, 500gb would be fine just because you already have a hdd but If you 're replacing it and really need a lot of storage 1tb should be fine since it's enough for a lot of mass storage. Otherwise get a 500gb ssd and keep your hdd or replace it with a newer one.
