T Tryte Distinguished Jul 2, 2014 27 0 18,530 Sep 21, 2014 #1 I know there is about 11.2" with drive bays in the nzxt h440 but you can remove them and I would like to know if my GTX 980 will fit in there without the bays, how much more clearance do you get? Thanks
Solution RazerZ Sep 21, 2014 GPU Clearance With HDD Cage: 294mm GPU Clearance Without HDD Cage: 406.2mm http://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html# Check to see if your 980 can fit with or without removing a drive bay.
RazerZ Judicious Ambassador Aug 18, 2013 9,961 0 33,960 Sep 21, 2014 Solution #2 GPU Clearance With HDD Cage: 294mm GPU Clearance Without HDD Cage: 406.2mm http://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html# Check to see if your 980 can fit with or without removing a drive bay. Upvote 0 Downvote Solution
O Omar101 Reputable Sep 21, 2014 6 0 4,510 Sep 22, 2014 #3 My 780 ti which is the same size fits with the drive bay Upvote 0 Downvote
TheMagicalWallaby Dignified Oct 9, 2013 2,693 1 13,960 Oct 18, 2014 #4 It can fit. Without the bays, you can fit any card that is as long as the case (no card is that long), but not wider that the room available. Upvote 0 Downvote
