Hi,
so its currently winter here and the air in my room is really dry from the cold air and heater. I just purchased a humidifier online to kind of fix this issue and also came across some forums stating that having a humidifier in the same room as my PC could potentially mess up the internal components if there is a high level of humidity(some say 50-60% while others say 40-55%). However I wasn't able to find just how much humidity is considered a high level hence I came to seek some advice here. Has anyone had any problems using a humidifier while having their PC operate in the same room? I made sure that the humidifier I bought had a limit to how humid the air could get but I'm a bit afraid that if I set it too high, my PC might break. Any advice would be appreciated.
Thanks
Thanks
