Hello, i have overclocked my 3 years old PC with GA X58A-UD3R, 1066MHz RAM and 550W PSU with i7 930 to 3.8GHz, this is my first time overclocking, i have made the adjustments to uncore and qpi. Core voltage is at 1.23... It is a D0 revision processor... i had it yesterday at 3.74Ghz without HT at 1.21 and ran intel burn test for 50 cycles, it passed (note that i have a 32 bit win7 with 4 gigs of ram (6 gigs by hardware, 32 bit os wont use more than 4) , so i cant use maximum for testing, it is also a free version 😀, i can only use 1500MB for testing, or standard) i also ran Prime95 for 8 hours at max heat and power comsuption, no errors... Today i clocked it to 3.8 with HT enabled and as i said, core volts at 1.23v, clocked my ram from 1066 to 1448 with 9 9 9 25 timings and 1.6 volts, BCLK 181, X21 multi, 3077 UNcore, 6516 QPI, it has been under normal usage and ran some benchmarks like passmark, cinebench etc, no errors, i also ran IBT for 25 cycles and it passed, (temps are fine, 81c max on one core, others were 79-80, im not gonna get these temps in real life usage anyways, right?) my question is, is it possible to have my system stable at these specs? How many passes should i do with IBT with 1500MB of memory to know my system is stable? How many hours of Prime95? Wherever i look i find different advice for stability testing and opinions on which is better prime or IBT so i thought id ask here... And pls, dont be hard on me, it wasnt me who assembled this PC (even i know 32 bit OS and 6 gigs of ram dont go hand to hand 😀) and like i said, first time overclocking...
