How much performance difference will be between i7 3770k @4.1ghz and @ 4.7 ghz?
Karadjgne
Herald
Depends on the game, the settings, gpu etc. In a game like skyrim with no mods, you'll barely see a difference, but add 100+ mods and you'll see a difference as those mods are scripted, pure cpu. Faster cpu will mean more mods without loosing fps. Other games you may see a difference depending on the gpu. If the gpu is strong enough to handle anything thrown at it, your fps will go up. But if the gpu is taxed it won't be much if any difference.
So it'll only really be something noticeable if you are at limits, if there's room to move then you are increasing performance thsts not used.
ZW____
Commendable
May 10, 2017
33
GTX 1070
