Hello, I'm building a new "gaming pc" and so far I have chosen as followed.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811322019
Sentey Extreme Division GS-6500R Burton Red Tower Case 6x Fan LED/ 4 x USB / Multi Card Reader / 4 x Fan Control / E-SATA / 6 x Removable Aluminum Bays / Screwless
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130910
EVGA 02G-P4-3658-KR GeForce GTX 650 Ti BOOST SuperClocked 2GB 192-bit GDDR5 PCI Express 3.0 SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211457
ADATA XPG Gaming Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GC4G9-2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285
AMD FX-8320 Vishera 3.5GHz (4.0GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8320FRHKBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192
SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
How much watts do you think I will need for this? Also if you have any recommended changes they would be much appreciated. I mostly play WoW and Skyrim, and a couple low run games like football manager but I might wanna try some newer mmo's like guild wars 2. No intensive FPS though really.
That all adds up to 787$ and my budget is around 1000, but I need to buy a new monitor as well.
Thanks in advance, just from looking at the front page I see you guys get a lot of these threads.
