how much power I need for this pc
sensi
Please tell me how much power I need for this pc:
CPU: Intel Core i7 - 3.2GHz - 960
Motherboard: GIGABYTE: GA-X58-USB3 ‏(rev. 1.0)‏
Ram: 4G
VGA: NVIDIA GeForce 9600
HDD: 1TB western digital
1 DVD writer
and using 6 port USB for devices such as DVB, iPHone, Camera ,...
thanks
Gobble45
67
No worries, happy to help.
if our answer was helpful, please select as a best answer.
There are two versions of the GeForce 9600 GT.
The original version has a Maximum Graphics Card Power of 96 Watts which required the use of a 6-pin PCI-E supplementary power connector. For this version NVIDIA recommends a minimum of a 400 Watt or greater power supply with a minimum +12 Volt continuous current rating of 26 Amps or greater and with at least one 6-pin PCI Express supplementary power connector.
The later version, Green Edition, based on the G94b GPU has a Maximum Graphics Card Power of 59 Watts and didn't have or require the use of a PCI-E supplementary power connector. For this version NVIDIA recommends a minimum of a 300 Watt or greater power supply with a minimum +12 Volt continuous current rating of 18 Amps or greater.
