(If the category is incorrect, I apologize. This is a bit of a hybrid thread that I thought was too short to split into multiple threads.)
I plan on buying a 780 ti and I need to know just how much juice I need to run it.
Currently I have an A8-5500 CPU, a 7790 GPU, and a 430w power supply (which I got because New Egg said I needed it).
I will be getting a 780 ti and a new processor soon-ish and when I used the Newegg Power Supply Calculator it said I needed at least a 1166w power supply to run it, which I'm pretty sure is bs.
So, my questions really are:
1. If I get the 780 ti now without anything else new, would my Power Supply be able to run it?
2. If not, then what power supply would I need (along with room to upgrade the processor)?
The next section is much more simple (in that it requires less specifiers).
My current motherboard has an FM2 slot which means the best CPU that fits is an A10-6ish. So would an A10 bottlneck a 780 ti? If so then its down to an i7 versus an FX (and I really don't wanna fork over that much money for a cpu).
