Question How much power PSU I need ?
Sep 18, 2021
24
Seems to me for 10+ years, my Zalman 850 did not work correctly any more...
Please advise me how much power I need:
Core 11400
ASUS Z590-P
16 GB DDR 4 HYPER X
GTX 980
SOUND BLASTER
and the usual's as DVD ROM, 2 SSDs, etc.
In general, PC for gaming. There is no point in overpaying for 850 watts?
DSzymborski
So even if I buy in a year Geforce 3080 I will be safe with 750 watt?
Probably, though 850W is recommended because the 3080 is very spiky.
However, that's a quality PSU. It's hard to say without knowing the exact model, but Zalman sells a lot of low-quality PSUs, some at high wattages, and if you have one of those, you lucked out by not having enough damage to the PSU from years of poor voltage regulation and high ripple to have a problem you could see with the naked eye.
Sep 18, 2021
24
[/QUOTE]
My current model is ZM850-HP. It doesn't look like a low quality model... The only issue I have with it now is 3,744 V (highlighted in red in Bios) instead of +3,3 V
DSzymborski
That is a low-quality model; ancient, group-regulated (this can be seen by the fact that it can't do anywhere near its total output in +12V power) and very inefficient. Basically on a 15-year-old Enhance platform with cheap capacitors and limited filtering. Wouldn't run a GTX 980 with this, let alone a 3080.
Sep 18, 2021
24
Which PSU models around 850 W you can recommend me? Thanks!
Eximo
Ambassador
RM850x is a solid unit. Running an i9 and 3080Ti off of mine at the moment. Using every single PCIe and EPS connector, GPU definitely crashes before the PSU gives up (still dialing things in though)
Sep 18, 2021
24
DSzymborski
Reactions: Swiftbasic1978
Sep 18, 2021
24
Thanks. I have installed Corsair RM850X (2021 Edition).
Quick question - I have Geforce 980. Do I need to plug 2 different 8 pins PCIe to PSU and to video card? Each cable has additional 8 pins on one end.
SO the question do I use single PCI e and use both 8 pins or I need two separate PCIe?
Always best practice to run two separate cables from the power supply. And if your case has a cutout in the bottom where the power supply goes, that can be used to draw cool air into the power supply and then exhaust out the rear of the case with the fan facing down and is better in my opinion. If there's no cutout, fit it with the fan facing up as facing it down with no cutout would mean it wouldn't be able to draw in cool air.
Why FAN up? Even if this case has a place for taking the air from the bottom?
Jon is also right, you can do it either way. I prefer the power supply pulling in cold air from the bottom and that air never entering the case. But if you have the fan facing up, it can also act to pull warm air out of the case.
If you have a case with good airflow, I'd mount it facing down. But if airflow isn't so good, might want to have it facing upwards sucking hot air out of the case.
