How Much Power Will My Gaming PC Need?
Apr 18, 2018
32
I know I could have used pcpartpicker.com, but it doesn't have a lot of the parts I'm choosing to use in its database.
MOBO: ASRock Z370 Taichi
CPU: i5-8600 OR i7-8700 (not getting unlocked versions because the Taichi supports BCLK overclocking)
GPU: NVIDIA GTX 1070 FE
MEMORY: Patriot Viper 16GB 3600mHz LED OR G.Skill TridentZ 3600mHz
FAN: be quiet! Dark Rock Pro 4
How much power do I need? I plan on overclocking at least a bit. Is there any specific PSU you would recommend? Thanks!
justin.m.beauvais
Respectable
Dec 15, 2017
1,062
32
2,240
232
Need and how much you should get are different questions. It only needs about 350-400 Watts, however, a 600 Watt power supply should be your target. Having a 600 Watt power supply will keep the PSU from being stressed, it will run more efficiently, more quietly, and cooler. It will also extend the life of your PC. Having a 600W will also give you some headroom for upgrades later. My suggestion is that you get a 600 to 650 watt power supply from a reputable brand with at least a bronze rating. That should keep you good on power for a long time.
Apr 18, 2018
32
Sounds good, that's what I was thinking. Thanks!
genca
Notable
Dec 5, 2017
404
17
As Justin said, get bronze plus 650w psu and you are fine. And i5 8600k is 238 dollars(i know that you will get non k but i cant find price for non k) while i7 is 300 dollars. You can save that 62 dollars and buy gold plus psu
