How much power will my gaming pc need?
Dec 9, 2018
Hello everyone, my name is Thomas, I’ve made a parts list for a pc im going to build, but I dont know how to figure out what type of PSU I will need. Could you also tell me how to work out how much power is needed on my own so I can also check.
Here’s my current parts list:
Case: Aerocool P7-C0 Dual TG Mid Tower Case Black
Motherboard: ASUS ROG Strix X470-F Gaming Motherboard
CPU: AMD Ryzen 5 2600X with Wraith Spire
CPU Cooling: Cooler Master MasterLiquid ML240L RGB AIO Cooler
RAM: Team T-Force Night Hawk RGB 3000MHz 16GB (2x8GB) DDR4 Black
GPU: ASUS GeForce GTX 1060 Turbo 6GB
HDD: Seagate Barracuda 2TB ST2000DM006
SDD: Crucial BX500 2.5in SATA SSD 240GB
Case Fans (x3): Aerocool P7-F12 120mm RGB Fan
The power supply I was thinking of using is the ‘Corsair CX650 650W Power Supply’, I’m not sure that 650W is enough power for my pc. I don’t want to have a weak power supply because I’ve read that that can damage other parts of the computer.
Thanks for the help!
laviniuc
Splendid
Nov 29, 2013
5,358
899
it's plenty, the pc will need about 300-400W even if you oc it, so 650 is good even if you plan to add more stuff to it.
LordVile
Respectable
May 27, 2016
967
32
That’s plenty but you should probably drop to a B board and bump up to a 1070 for better performance
