How much power will this pc need
DariusK
7
Hi Guys:D
I need your help !:)
here are my components :
Intel Haswell core i7 4770K
Asus Z87-A
Corsair 1600 2*8 1.5
Samsung 840 evo 250
Western blue 1tb HDD
Lian-Li PCK-57 case
I'm planing to use onboard graphic for dual monitor for now . maybe a high end gpu and psu for later .
will a Corsair VS450 do the job ? or a decent 330w psu is enough ?
Thanks a lot
very much appreciated
Scremin34Egl
1,437
238
If you plan on getting a gpu later on, get a 550 to 600 watt 80+ certified psu from brands like corsair, Antec, Seasonic, xfx. I wouldn't get the VS series as they are bottom line psu's from corsair that use cheap components
DariusK
7
thanks a lot you guys :)
can u recommend some durable psu ? for the rig mentioned before and a asus 770 gtx . also I'm not going to overclock anything , stock setting should be far enough for me .
Thanks Thanks Thanks :love:
DariusK
7
thanks for replay man
so with adding GTX 770 to the build a 650w silver or gold certified would be good ?
p.s : sorry for poor English . It's not my native language
thang again
Similar threads
