How much rpm is my hard drive running at?
mate.mindak5
Commendable
Feb 21, 2018
6
Don't get triggered, I've done my research but I couldn't find out how much rpm is my drive running at.
So I've checked it in like 3 programs, and checked the sticker irl, and couldn't find it out.
Here's what I know :
It's a "Toshiba dt01aca100 ata device"
Local Fixed Disk
NTFS
462EFDD2
200 GB (Although the sticker on it irl says 1tb, just like several programs and if I type it in google it throws out 1tb toshiba drives with the same name)
6 gb/s
(2013, made in china)
No way!
The model number is not lying.
It's possible that it's not partitioned correctly.
I'm sure that you'd be quite surprised if you'll have a look in disk management!
No way!
Woah, that's weird. So I've downloaded a program called "easeus partition master" and it actually says that I have 730 Gb unallocated memory. (+200 that I'm using + 100 for the system)
Feelsbad that I was using 200 gigs when my drive is actually 1 tb (and obviously everything is slower if the space is almost full, I haveo only like 10 Gb left)
Sorry for the stupid question, didn't know it works like that.
Thank you, I would have bought a new hard drive if you didn't help.
And btw 7200 rpm, sata3 and everything, so it should be okay for gaming, right?
And thanks once again
