How much watts does a 450w power supply sucks from the wall
Usman Sajid
669
I have Delta 450gps aa power supply.
GTX 750 ti Oced
Core i5 2400
4 ram sticks
1hdd
2fans
I want to know the power supply sucks full 500w ( 450w + extra watts which are wasted in heat e.tc)
or sucks only watts it needs.
+1 @ hunter315
Also, how many watts it pulls from the wall will depend on the PSUs efficiency. If you have a gold rated it will waste less energy as it pulls from the wall. Although the difference wasted between a gold an bronze typically isn't worth the extra spent to get the gold.
+1 @ hunter315
Yes, it is ok to run a computer 24 hours a day. Of course it will affect the lifetime of the system, especially if you are running at high load 24/7.
It is best to use the shutdown option for turning off your computer (unless you have your power button set to shutdown as opposed to holding the button for 5 secs and doing a 'hard' shutdown). On my computer, pushing the power button is the same as choosing the shutdown option in windows.
