Thank you for taking your time first of all,
Currently I have 1 stick of DDR4 2400mhz ram (16GB), so technically 1200mhz.
I was told i would get higher results if i upgrade to dual channel, i have 2 options, either sell the memory i have right now and buy 2x8 (16GB) 3200mhz, or buy the same of the current and do 2x16 (32GB) 2400mhz,
Bottom line is, What will display better results? More RAM or faster RAM? is it even worth upgrading?
I feel like something in my pc is not performing as it should be and i feel like the ram is the bottleneck.
Gaming regularly i deal just fine but when i stream i do not have great results while others running the same if not worse (GPUS&CPUS) deal just fine.
CPU: I7 6700K, OC > 4.6 GHZ Cooled by Corsair H100i V2
GPU: MSI 1070 GAMING X 8GB
Motherboard: Z170 Pro Gaming
SSD: 480GB TEAM L3 EVO
Power Supply: Corsair CX750M
