How much will it help?
Flibbi_boi
74
Hi, I am using two Zotac gtx1080 ti fe cards for my to-be setup. I am getting 3 4K 60hz monitors and I ma wondering if it can run smoothly on 4K over 30fps. Here is my list for more information
https://pcpartpicker.com/list/
Don't get FE cards if you don't have them already, wait a few weeks and get aftermarket cards, they'll cool and perform significantly better, you'll regret it later if you don't wait.
Budget for your build?
Thanks for the advice but I can't find any 1080tis without fe
They're not out yet which is why i'm telling you to wait. 😛
You can get the rest of the stuff though.
What is your budget including GPUs and monitors?
Also you posted the generic link to your list, that refers to the user's personal list.
Post the permalink in the top left corner.
Ok thank you very much! I will wait until they are released! My budget is low $5000
I suggest getting one 4k monitor to start with, and then later down the line getting the new PG27UQ, if you haven't seen that monstrosity yet, give it a google.
Acer will also serve up an identical alternative which could be an option.
It'll run 4k 60fps with a single 1080ti, with two of them it'll be out of this world with the monitor I mentioned.
4k, 144hz, HDR, G-Sync, 27", IPS literally everything you could ask for in a monitor.
It'll release later this year and retail supposedly around the 1k mark, well worth the wait based on first impressions of the monitor and visual analysis.
Remember to ping this thread again when aftermarket 1080tis are out and i'll recommend two for you.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor ($343.49 @ OutletPC)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler ($46.88 @ OutletPC)
Motherboard: Asus STRIX Z270-E GAMING ATX LGA1151 Motherboard ($188.99 @ SuperBiiz)
Memory: G.Skill TridentZ Series 32GB (2 x 16GB) DDR4-3200 Memory ($234.97 @ Jet)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive ($167.88 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($78.99 @ Amazon)
Video Card: Zotac GeForce GTX 1080 Ti 11GB Founders Edition Video Card (2-Way SLI) ($698.99 @ SuperBiiz)
Case: NZXT S340 Elite (Black/Red) ATX Mid Tower Case ($89.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($119.99 @ Jet)
Monitor: Dell P2715Q 27.0" 3840x2160 60Hz Monitor ($539.00 @ Amazon)
Total: $3208.16
Generated by PCPartPicker 2017-03-27 01:28 EDT-0400
Yep, immersive displays, wraparound gaming, more space for me to open all my apps in
Ok, but the monitors I'm getting are 4K and not very expensive, so I think stay with the same monitors
