Question How much would I get for? Already Built.
edward78
443
MSI Performance Gaming AMD Ryzen 1st, 2nd, and 3rd Gen AM4 M.2 USB 3 DDR4 HDMI Display Port Mini-ITX Motherboard (B450I GAMING PLUS MAX WIFI, AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked Desktop Processor, TEAMGROUP T-Force Vulcan Z DDR4 16GB Kit (2x8GB) 3200MHz (PC4-25600) CL16 Desktop Memory Module Ram (Gray) - TLZGD416G3200HC16CDC01, ZOTAC Gaming GeForce RTX 4060 8GB Solo DLSS 3 8GB GDDR6 128-bit 17 Gbps PCIE 4.0 Super Compact Gaming Graphics Card, ZT-D40600G-10L & SK hynix Gold P31 1TB PCIe NVMe Gen3 M.2 2280 Internal SSD, Up to 3500MB/S, Compact M.2 SSD Form Factor SSD, Internal Solid State Drive with 128-Layer NAND Flash in Aluminum Mini ITX Case with PCIe Riser, JOYJOM Mini PC Case, SFF Small Form Factor PC Case, TX Computer Gaming Case supports GPU Graphics Card (Black) BTW the cooler limitation is wrong, a 37mm is in it now, no isues also.​
IMO probably a $4-500 system if it is used, maybe a little less according to demand in your area. If it a new build with receipts and warranty a lot of different factors to consider there. Mostly, who are you to the building community, do you have a reputation as a known good trader and so on.
Reactions: Roland Of Gilead
