Question How Nvidia control panel changes GPU temperature and load
Aug 27, 2019
Hello everybody!
I have the following question/problem. I've watched a video dedicated to tweaking some setting in Nvidia control panel to get a boost in GPU performance. Currently my GPU is RTX 2070 which usually works with only 5% load and around 38-41 degrees Celcius while idling. Now, having changed a very significant option (as was said by that YouTuber) of power management from "quality" to "prefer maximum performance" I am experiencing not only a higher temperature of my GPU, but also a higher loading rate (it went from 5% while idling to 25%). Now, is that o'kay at all? Should the temp. be that way or there's something wrong?
Thank you!
Latest posts
