How often should I dust out my power supply?
Ryuji2
20
I have this as my power supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
I bought parts for my rig back in 2011 and every part has been working like a charm for these past 4 years. I dust it out every 2-3 months or so, sometimes a little longer if it's in the winter months since I generally keep my room cool during the winter and the house doesn't get too dusty.
However I never really unscrewed my power supply from the case to dust it out, just kinda left it alone. Also I have never opened a power supply to clean it out and the warranty on my PSU will last until April or so of 2016.
So my question is, should I try to at least pull my power supply out of my case to dust off the grill and maybe poke at the fan blades or something, or just leave it be and take advantage of the warranty if or when the PSU gives up? Also I don't have any PC repair shops nearby so asking someone else to clean it isn't really an option.
Am I just bad and should go ahead and attempt to dust it instead of ignoring it? I'm fairly well versed in PC maintenance/installation/etc. except for 2 things, cleaning a power supply and installing liquid cooling, so...
Often actually using the warranty is such a hassle that it is far preferable to do what you can to take care of it yourself. You should not open it if you are not familiar with working around high voltages and by familiar, I mean you have a sincere respect for the danger, not simply feel confident that nothing bad will happen to you. But if you never open one up, then how will you learn? 😀
You can make an adaptor to attach a straw to a regular vacuum cleaner and remove some of the dust through the grill. (Look up how to do this because if you do it wrong, your vacuum cleaner might overheat, but most have a safety trip which will reset after an hour.) You should definitely unscrew it from your computer's case if you need to. The power...
Right. First things first, NEVER open a power supply unless you really really know what you're doing. The capacitors can hold large amount of electricity long after they have been turned off. Secondly, what you seem to be doing now sounds great. Just keep doing that and don't forget to use an air duster if you're not already using one.
Hope this helps :)
http://www.howtogeek.com/72716/how-to-thoroughly-clean-your-dirty-desktop-computer/
How To Thoroughly Clean Your Dirty Desktop Computer
Looked at that, saw the person didn't remove it from the case and his PSU is on the top, mine's on the bottom with the grill facing down. There is no way to reach it without unscrewing it from the case which leads to my original question of whether I should remove it to attempt to dust out the grill and fans or to just leave it be and hope it holds out either until the warranty letting me get a new one, or building a new rig or something.
To get an idea of what I do, I don't do any intense gaming but I do play stuff like WoW on near-ultra settings(some recent changes made it pretty demanding if you wanna max it out), Dragon Age Inquisition on mostly high to near ultra settings with mods to increase texture quality and the like, things like that.
What little air I feel that comes out of my power supply is quite hot, and am wondering if I should try to get more airflow going, lest it blows up or gives out.
You can make an adaptor to attach a straw to a regular vacuum cleaner and remove some of the dust through the grill. (Look up how to do this because if you do it wrong, your vacuum cleaner might overheat, but most have a safety trip which will reset after an hour.) You should definitely unscrew it from your computer's case if you need to. The power supply is inside its own case that is simply screwed to the computer case. It's not really yours until you void the warranty. That's why if you send it in on the warranty, they have the option to replace it with a refurbished model. If it breaks, you can learn to fix it, if you want to. Otherwise, get what you can with a straw and don't worry about it.
In general, the fact you can feel hot air blowing out is a good sign. When too much dust covers the parts then the heat won't transfer and then instead of blowing out hot air, it will boil an electrolytic capacitor or several.
It's good for your computer to get warm because that keeps out humidity. I am in a humid environment, so I try to keep mine running all the time. Turning the computer on and off actually causes more wear than leaving it on, in theory. The temperature fluctuation causes expansion and contraction of the joints. Keeping your computer at a constant temperature, even if it feels hot to you, is better than letting the temperature fluctuate.
Of course you can't help that it is going to fuctuate as you use it. The best you can do is reduce the range of fluctuation.
Trying to keep it too cool can increase the range of fluctuation. You want the computer to be comfortable, and just as you don't set your thermostat to freezing just because it's hot outside, so too, all you want to do is provide a way for your computer to maintain a reasonable temperature. It is what, a 300Watt power supply? Compare that to a 300Watt incandescent bulb or a 300Watt heater. You can expect it to put out some heat. On the inside, it is feeling fine. If it feels cool coming out, then I would worry something is wrong.
Bottom line: 3 months or as needed is a good maintenance schedule.
