how "positive" must airflow be for a tower case to keep du..
G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking,alt.comp.hardware.overclocking.amd,alt.comp.periphs.mainboard.asus (More info?)
I'm upgrading a case (and the system inside it)? Actually two such
systems. I want to have positive air pressure in the case sufficient
to keep out dust. If you know this design, it has vents on the sides
of the case near the top, plus a row of vents in the back above the
adapter cards:
Both cases will have an ASUS A7M-w266 D,TBred 2000, no overclocking.
Power Supply is an Antec TruePower 550. (assume 0 cfm out at lowest
fan speed, 40 cfm at highest fan speed)
Cases are an Addtronics 7896A and a 6896A.
Assume roughly 140 cfm in. (2 120 mm Panaflow "L" model)
So, my question is:
How positive do I need to keep the case air pressure, to keep dust
out? That is, how much more should the cfm in be compared to the cfrm
out?
Paul
Splendid
Mar 30, 2004
5,267
In article <0m89g09l8i0g8fcq6e5eqhcq9ir5atusg8@4ax.com>,
> adapter cards:
> So, my question is:
> out?
I just tried "computer dust positive pressure" on altavista.com
and one of the first hits was this.
http://www.dustfreepcinfo.com/pages/184710/index.htm
They use filters before their fans that pressurize the cabinet.
Thus, clean air is used, and blowing that clean air under positive
pressure, through any opening in the cabinet, prevents dust
from entering.
If your case blows dirty air in, I don't think it really matters
what differential there is between "in" and "out". As long as there
are dead spots in the case, where the air velocity is lower than it
was originally, the particulate will settle out. (My thinking here,
is that dust works on the same principle as silt in a river - as
soon as the river widens and the water velocity drops, the silt
falls out and collects on the bottom of the river.)
To implement a solution like those dustfreepc people, you will
need micron filters, a plenum, and your large 120mm fans. A plenum is
simply a length of plumbing leading from the filter to the fan, and
keeps the filter from getting too close to the fan blades. About
3" of plenum between the filter and the fan should be good. You
can try mounting the filter right on top of the fan, but you'll
probably hear more noise coming from the fan that way.
As soon as you use filters on a PC case, then you've got a maintenance
item. The filters have to be cleaned or changed every x months. You
have to remember to do it. If you forget, the computer might overheat.
The most endangered component is probably the disk drive, and
the computer will continue to run quite happily under conditions that
are trashing the disk.
Some other threads from my search:
http://forums.pcper.com/showthread.php?s=&postid=2029294
http://forums.overclockersclub.com/?showtopic=8412&st=10&
The interesting tidbit on the following site is
CFM = 3.16 x Watts / Delta_T_degrees_F
http://www.chassis-plans.com/cooling_and_noise.html
Using the AMD recommendation of a max case temp rise of 7C, which
is 12.6F, and assuming 200W for a high end PC, we get 50 CFM.
This one is a home brew solution, using an air cleaner filter
replacement as the filter for the air. Positive case pressure
is created by two identical fans, with one running 200RPM higher
than the other:
http://www.silentpcreview.com/Sections+index-req-printpage-artid-144.html
So, if the air is filtered, then a positive air flow seems to be
the solution offered by commercial designs. For unfiltered
situations, a balance between in and out, or a slight negative
pressure seem to be favored.
I can tell you that one computer I use, which has only exhaust
fans, is filthy inside. Yet, I've never had any trouble with
the floppy or the CD on that computer.
This is one of those questions, where if you ask twelve
people, you'll get a dozen different answers :)
HTH,
Paul
G
Guest
Guest
It's probably as good idea to get one of these...
http://www.directron.com/110alert.html
I have one near my HD.
Prang
G
Guest
Guest
How would that keep out the dust?? It would seem if any fans are blowing in,
they would bring in dust with the inbound air and any positive air pressure
inside the case would limit the amount of incoming air for ventillation.
Don't get me wrong, I would like to see a solution beside airflow limiting
filters since I have cleaned out dustbunnies of record size and number from
a few hundred enterprise computers over the years and I would like very much
to keep the dust out of my new build.
MkeSp
"Winey" <NOSPAMME@no-one-here.com> wrote in message
news:0m89g09l8i0g8fcq6e5eqhcq9ir5atusg8@4ax.com...
> adapter cards:
> So, my question is:
> out?
G
Guest
Guest
Unless you have filters on the air inlets the dust is gonna get into the
case anyway.... and if you do have filters then the performance of the fans
will be much reduced.
If you have filters and want to ensure positive pressure then the only sure
fire way is don't have any exhaust fans.
*****Replace 'NOSPAM' with 'btinternet' in the reply address*****
> adapter cards:
> So, my question is:
> out?
G
Guest
Guest
Amir Facade wrote:
> I think the exhaust hose on a medium size shop vac would do the trick
> nicely.
You included over 100 lines of previous post, what ARE you talking about?
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
G
Guest
Guest
> >to keep out dust.
G
Guest
Guest
>>> to keep out dust.
Bloody hell. learn how to post.
The exhaust system from a vac would be warm air and not ideal. Might be a
bit noisy too.
Ben
G
Guest
Guest
"NEM" <NoE-Mail@FakeAddress!.corn> wrote
> By making the room the computer sits in have less dust to begin with.
Air cleaner with filter!
Ion generator to stick dust to the walls!
Ed Light
Smiley :-/
MS Smiley :-\
Send spam to the FTC at
uce@ftc.gov
Thanks, robots.
G
Guest
Guest
notritenoteri wrote:
> ever thought of vacuming out the guts once in a while?
Yeah, but the static build up worries me.
Of course compressed air (or LPG or..) would be more suitable
Ben
G
Guest
Guest
Bx.Cornwell wrote:
> you'd think that computer case engineers (designers?) would at least be
> keeping an eye on things like that...
BTX design should improve a whole load of things, apparently.
Ben
G
Guest
Guest
On Mon, 26 Jul 2004 15:05:15 -0500, in <three different newsgroups>, "Michael
> in, they would bring in dust with the inbound air
[snip]
The presumption is that any/all inward-facing fans would be drawing through
proper washable/replacable-element filters. Most of your better case designs
make provision for this (tho' far too many of them -- including such
"high-end" brands as Lian-Li -- then effectively defeat it by adding way too
many *exhaust* fans, thus making it difficult/impossible to avoid a negative
internal case pressure).
> ... and any positive air pressure inside
[snip]
In theory, perhaps. But as a practical matter, you'll never generate a
significant pressure differential, let alone one sufficient to have a
noticeable effect on this. The cases are just too "leaky".
> much to keep the dust out of my new build.
[snip]
Proper filters on the supply fans will never have an excessive negative effect
on airflow *if* two things are true:
1. - The fans (and filters) are properly sized for the task in the first place
(and permitted to run fast enough to do their job, of course).
2. - The filters are kept clean.
Jay T. Blocksom
Appropriate Technology, Inc.
usenet01[at]appropriate-tech.net
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety."
-- Benjamin Franklin, Historical Review of Pennsylvania, 1759.
Unsolicited advertising sent to this domain is expressly prohibited under
47 USC S227 and State Law. Violators are subject to prosecution.
G
Guest
Guest
On Thu, 29 Jul 2004 15:03:08 GMT, in <three different newsgroups>, "Roger
Hamlett" <rogerspamignored@ttelmah.demon.co.uk> wrote:
[snip]
> Dust was the reason the original IBM design, had the rear fans blowing
> into the case. The idea was that the intake here was higher, and further
> from the carpet/user, and the outflow of air at the front would keep the
> floppy disk from filling with fluff.
[snip]
Uhhh... No.
First, "the original IBM design" (in fact, the first *several* IBM-PC designs)
used a "desktop" (i.e., horizontal) case; so the fan was *not* (significantly)
higher than any other part of the system. It wasn't until the "PS/2" line
came along that IBM offered a "tower"-style PC.
Second, the unfiltered inward-facing fan was a product of basically two
factors:
1. - They weren't really concerned with force-cooling any other part of the
system beyond the PSU itself; recall that the CPUs didn't even have passive
heat sinks, let alone active (fan-driven) ones. It simply wasn't an issue.
2. - $$$. This was _the_cheapest_ way to accomplish what they set out to do.
Jay T. Blocksom
dallas
1,553
"Winey"
> out?
I'm sorry if this is already covered in this long thread, I didn't have time
to read it.
I would think anything positive will work, airflow is deciding factor in
cooling. I just used packaging tape to cover every vent opening in the case
and have three fans blowing in and two blowing out. A filter is a great
idea if you clean it once a month. I just went to Home Depot and rigged
something up with some AC filter material. Simple, cheap and works great.
