Hello,
In a couple of days, I will be building my first PC into a Zalman Z11 HF1 case. I have 2 exhaust fans in the back (both 3 pin, case came with both), 1 intake fan in the front (molex that the case came with) and one intake fan at the bottom (3 pin, bought it as extra, relax, I have a dust filter). All of these are 120mm. The case comes with 2 more 80mm exhaust fans on either side in the front that are supposed to cool drive bays. I have several options in how to set them up:
1. Plug them in normally and let them run. This will probably result in negative pressure because I will have only 2 intake and 4 exhaust but I'm not sure because they're only 80mm.
2. Turn both around and plug them in. I will probably have positive pressure in this case because there will be 4 intake and two exhaust, but can there be something like too much of positive pressure? Once again, I'm not sure because they're only 80mm.
3. Turn one of them around and have constant cool air going over the drive bays. I'm not sure if this will work because of the 120mm front fan that the air is gonna go past.
4. Not plug them in at all and have balanced air pressure.
Which one of these would work best? If you need any additional info, please ask.
