How should i lay out my case fans?
taylorwallace9
72
Hey everyone, i have come to notice that all my case fans are being used as exhaust, none for intake. I have an Antec Darfleet DF-35 Midtower. It comes with 4 pre-installed Antec fans. Do any of you recommend i lay out the fans differently to achieve better cooling? The positions of the fans are two in the lower front (where the HDD's are located. One on the top (above the cooler) and one on the rear (just above the videocard) Thanks in advance.
It is a great cooler that, I am thinking about going to the Corsair H60/70/100 range sealed liquid cooling, it is mounted away from the motherboard and in particular the RAM/CPU area and gives you the option for a extra fan.
I have the CM 690 II KKN3 which has room for up to 11 fans so venting is not really a problem, despite using a clumsy CPU cooler myself.
On performance the Noctua is better comfortably so, than the H60, the H100 is probably the right comparison, but the H100 radiator needs two 140mm intake vents on the top or bottom to mount it, while the H60 is a single slot.
The whole question is simple though to clock a 2500k to 4-4.5 which is what most boards will support at stable performance, how much cooling does one really need. That said the noctua is just amazing.
yea it turns out the front fans were actually on intake, i must of felt the airflow wrong lol. but i was using the stock intel fan so i could bring my pc in, it would not turn on, but that is resolved, and i was running Core Temp and the idle temps were in the high 50's. I just swapped it out again for my NH-C14 and my idle temps are low 20's :) been running prime95 for around 15 minutes now and the temps are high 40's and very low 50's. I did install it a different way and i now have more room and great air flow. Anyone recommend a quiet 120mm fan, preferably with blue or white led's
