How should I mount my Dual XSPC 170 Photon
Anazro
87
So I have a Dual/2x XSPC 170 Photon and I want to mount on upper right hand side of case right in front of the but in back of the Optical Drive bays.
How do I preform such task?
Sorta like this:
Assemble it with mount brackets attached. Hold it in place by hand.
You have to pencil mark where you want bracket mount holes drilled into the case. Hope they line up with existing holes.
Mount the bracket to the case then the reservoir to the bracket.
But if theirs air were the bracket screws go? What then do I drill?
