[SOLVED] How should i orient my fans?
Jun 14, 2020
i have 2 140mm and 3 120mm fans and my case has 6 mounting points with 3 in the front two on the top and 1 in the back. Can someone tell me what orientation of fans will give me the best cooling?
D
One 140mm rear & one 140mm top (right above the CPU), both set as exhausts.
Three 120mm front set as intakes.
If you want, you can leave out the top 140mm.
