I recently built a new rig using the Corsair 600c inverted case. I plan on removing all the stock fans and relacing them in order to match my color theme (black/white/red)
My question is, how should I place my case fans?
I currently have a 240mm radiator in the front of the case in a push/pull configuration. I plan on having a 140mm airflow exhaust fan.
my biggest trouble is figuring out what to do with the bottom fans.
Should I have them intake, or exhaust air out of the system? Also, since they are at the bottom, do i require static pressure fans or are airflow fans good enough?
The bottom fans will be controlled by a switch on the top of the case, while the rear exhaust and radiator fans will be pvm.
