how should i setup a sli water cooling system?
Johny Gat
24
i'm currently planning to invest in dual sli for the MSI gtx 970's and i'd like to overclock them. now the problem is i don't really know how to water cool them both. well i know i need an sli bridge but what else do i need? i've seen some sort of devices you put on top and put your tubing through it but i'm very nervous of getting a wrong type of waterblock/water cooling sli thing
EDIT: fixed some things
there are some youtube videos that could help you out with that. if you already have a custom liquid-cooled system (not those AIO systems like the H100, etc.), you'll need to get a couple of gpu blocks, fittings and tubes to connect them to your current system. if you don't have a custom LCS yet, the videos i mentioned can help you out there too. but be warned, it will cost a lot to do a custom liquid-cooled system.
