OK.It was Genymotion Android Emulator. I dedicated 2gb to emulate some phone.
Well then.4 GB
Yes, I know. I want to undo this somehow. Deleting a VirtualBox folders didn't help.Well then.
4-2 = 2
If you have 4GB, and you devote 2 to a VM...that leaves only 2GB for the host system.
In the VirtualBox client, turn that VM off.Yes, I know. I want to undo this somehow. Deleting a VirtualBox folders didn't help.
It was off all the time. Then I unnistalled Genymotion and VB, delete all the folders (I think so) and still I have only 2 GB of RAM avaialble :<In the VirtualBox client, turn that VM off.
Reboot.It was off all the time. Then I unnistalled Genymotion and VB, delete all the folders (I think so) and still I have only 2 GB of RAM avaialble :<
Ah, haha, yeah, I did it a couple of times.Turn your system OFF, then turn it ON again.
Unless you have VB on some sort of autostart, and that VM also starting...it can't do that.Ah, haha, yeah, I did it a couple of times.
80% of my RAM is used but as I said earlier I have only 2GB available (4GB installed).Unless you have VB on some sort of autostart, and that VM also starting...it can't do that.
Look in your Task Manager for what might be consuming your RAM.
And your actual hardware may be using 2GB?80% of my RAM is used but as I said earlier I have only 2GB available (4GB installed).
Yes my actual hardware is using only 2GB of RAM, I can feel it because it's so slow. I don't want to reinstalling my OS that's why I'm looking for another solution.And your actual hardware may be using 2GB?
You've not given us any details to work with, other than the 2GB that might have been devoted to a VM.
I should have 4GB available as usual but instead I have only 2GB. BIOS also shows 2GB. Reset didn't help. Maybe there are still somewhere VirtualBox files. I don't know.You've still given us no details to work with.
"Feels slow" means little.
If VirtualBox is not running, it cannot consume any RAM.I should have 4GB available as usual but instead I have only 2GB. BIOS also shows 2GB. Reset didn't help. Maybe there are still somewhere VirtualBox files. I don't know.
I checked my computer properties and it says "installed 4GB (available 2GB).If VirtualBox is not running, it cannot consume any RAM.
Especially in the BIOS.
Right. Your hardware( of which we out here do not know) is consuming 2GB.I checked my computer properties and it says "installed 4GB (available 2GB).
Eh, the issue is that 2GB disappeared somewhere and I need to get it back.OK, you have 2 RAM sticks of 2GB each.
What seems to be the issue?
