how to achieve maximum fps
subcool
Commendable
May 6, 2016
11
I am new and trying to understand the gaming pc, which components directly affect the frame rate in games obviously i want to increase it with the best settings possible so is it just the gpu or cpu ram mobo an ssd all of them im just not sure also is there a difference in single player games and the online shooter type games when it comes to achieving max fps? if you guys can bring me up to speed i would appreciate it!
There's no formula for that but it's usually graphic card that determines performance in games but it has to have appropriate CPU behind it and enough RAM. Single and multi user games are about same but it also depends on how a game is optimized. Some need better graphic card some more cores in the processor while other ones relay on single core processor performance.
Only one thing can be sure, get best parts for money you can spend and hope for best.
