How to activate wireless connection without the F2+F3 button for Acer Aspire 5750Z
FValoara
i dunno what happen to my laptop inbuilt keyboard, whatever i do or whatever i press ,not a single key respond. I had even check trough online keyboard test at :
http://www.keyboardtester.com/
and i found not a single respond not even ~ ,which i never used but in meantime i am using and old external keyboard with windows OSK.
Guys please please help me, This is a real PIA.
i search through whole internet through this keyboards combos,
and due this i am unable to activate wireless but rt now am using it as USB Tethered,
so there are two problems but first help me to activate wireless
SYS SPECS :
Operating System: Windows 7 Home Basic 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire 5750Z
BIOS: InsydeH2O Version V1.21
Processor: Intel(R) Core(TM) i3-2330M CPU @ 2.20GHz (4 CPUs), ~2.2GHz
Memory: 3072MB RAM
Available OS Memory: 2924MB RAM
Page File: 2867MB used, 2977MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
using dxdiag command
Hi,
Here are some troubleshooting steps that may do the trick for you.
- Open Device Manager then expand Network Adapters.
- Right click on the Wireless Adapter and see if you'll have an option for Enable.
- After these steps do try if you'll be able to connect to your wireless network.
If these doesn't work do try to uninstall/reinstall the wireless adapter itself.
- Go back to Device Manager and uninstall the wireless adapter.
- Download and install the latest driver from Acer Support site.
Atheros Wireless Adapter:
http://global-download.acer.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Atheros_9.1.0.334_W7x64_A.zip?acerid=634304191099246112&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205750Z&OS=711&LC=en&BC=ACER&SC=EMEA_27
Broadcom:
http://global-download.acer.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Broadcom_5.100.235.19_W7x64_A.zip?acerid=634468150755160501&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205750Z&OS=711&LC=en&BC=ACER&SC=EMEA_27
Intel:
http://global-download.acer.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Intel_14.0.1.2_W7x64_A.zip?acerid=634304189178187427&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205750Z&OS=711&LC=en&BC=ACER&SC=EMEA_27
Thanks for the reply,
Sorry i hadnt explain my problem properly as i have to type through osk
The thing is i had tried installing all the drivers but none of the installation make my wireless adapter to reappear.
what else should i need to be done...
i followed what you told here but still i dont see any wireless adapter neither at these locations :
-Control Panel\Network and Internet\Network Connections
-Device Manager List
-but at this location %windir%\system32\msinfo32.exe , i find that my wireless driver was...
[Adapter]
Item Value
Name [00000000] WAN Miniport (SSTP)
Driver c:\windows\system32\drivers\rassstp.sys (6.1.7600.16385, 82.00 KB (83,968 bytes), 14-07-2009 05:40)
Name [00000001] WAN Miniport (IKEv2)
Driver c:\windows\system32\drivers\agilevpn.sys (6.1.7600.16385, 59.00 KB (60,416 bytes), 14-07-2009 05:40)
Name [00000002] WAN Miniport (L2TP)
Driver c:\windows\system32\drivers\rasl2tp.sys (6.1.7601.17514, 126.50 KB (129,536 bytes), 21-11-2010 08:54)
Name [00000003] WAN Miniport (PPTP)
Driver c:\windows\system32\drivers\raspptp.sys (6.1.7601.17514, 108.50 KB (111,104 bytes), 21-11-2010 08:54)
Name [00000004] WAN Miniport (PPPOE)
Driver c:\windows\system32\drivers\raspppoe.sys (6.1.7600.16385, 90.50 KB (92,672 bytes), 14-07-2009 05:40)
Name [00000005] WAN Miniport (IPv6)
Driver c:\windows\system32\drivers\ndiswan.sys (6.1.7601.17514, 160.50 KB (164,352 bytes), 21-11-2010 08:54)
Name [00000006] WAN Miniport (Network Monitor)
Name [00000007] Broadcom NetLink (TM) Gigabit Ethernet
Adapter Type Ethernet 802.3
Driver c:\windows\system32\drivers\k57nd60a.sys (14.8.0.5, 415.04 KB (425,000 bytes), 10-05-2011 09:12)
Name [00000008] WAN Miniport (IP)
Name [00000009] Microsoft ISATAP Adapter
Driver c:\windows\system32\drivers\tunnel.sys (6.1.7601.17514, 122.50 KB (125,440 bytes), 21-11-2010 08:54)
Name [00000010] RAS Async Adapter
Name [00000014] Atheros AR5B97 Wireless Network Adapter
Name [00000016] Microsoft Virtual WiFi Miniport Adapter
Name [00000017] Alcatel Single RNDIS Interface
Driver c:\windows\system32\drivers\usb8023x.sys (6.1.7601.18076, 19.50 KB (19,968 bytes), 13-03-2013 13:51)
Name [00000018] Microsoft Teredo Tunneling Adapter
Name [00000020] Microsoft 6to4 Adapter
