How to add indicator lights to a PC case mod?
tristenbohn
Those LED's won't really work. They are only 120vAC or 24vDC.
Common easy voltages inside a PC are 5vDC or 12vDC. Then you could simply wire the light to a Molex plug and when the PC was power, the Molex would get power.
