B btr999 Distinguished Oct 17, 2013 118 0 18,680 Feb 2, 2016 #1 Is there any way to add usb3.0 header to the motherboard? My motherboard is Biostar H61MU3b with only usb 2.0 header. I am using cmstorm stryker casing and it has got 2 usb 3.0 port at front panel.
Solution BadActor Feb 2, 2016 You can also use an adapter cable, but the front panel port will only operate at USB 2.0 speeds. http://www.newegg.com/Product/Product.aspx?Item=9SIA7323GV2269&cm_re=usb_3.0_front_panel_to_usb_2.0_header_adapter-_-181-000F-00002-_-Product
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Feb 2, 2016 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16815287019 Upvote 0 Downvote
BadActor Expert Ambassador Oct 31, 2015 8,749 1 54,965 Feb 2, 2016 Solution #3 You can also use an adapter cable, but the front panel port will only operate at USB 2.0 speeds. http://www.newegg.com/Product/Product.aspx?Item=9SIA7323GV2269&cm_re=usb_3.0_front_panel_to_usb_2.0_header_adapter-_-181-000F-00002-_-Product Upvote 0 Downvote Solution
