How to add USB3.0 front panel to my non-USB3.0 system?
trale
34
bloojays23
76
Do you have usb 3.0 on your motherboard? On the back panel? If so, you can buy this THIS Which would connect to the 2 Usb 3.0 ports on the back of your motherboard , though it only has usb 3.0.
I had the same situation where my case had USB 3.0 ports on the front i/o panel but it required usb 3.0 headers on the motherboard which I didnt have, so i bought THIS. So if you wanted a USB 3.0 front panel that had the headers that look like this:
then it would work fine.
