how to add wireless to laptops internet connection
bubblegum101
The wireless connection is not showing at all in my internet connections.....my laptop is msi U135DX details as follows:
CPU:intel Atom N455
Led panel:10"WSVGA
RAM😀DRIII 1GB
HDD:320GB
RF:802.11b/g/n
Is your wireless enabled? It's rather easy to accidentally disable it my pushing the function key with the wireless tower on it and turning it off. Try going into control panel and making sure the wireless adapter is enabled and verify that the button or switch on your laptop is not turned off.
You can also try running the networking troubleshooter. What is your windows version? Have you changed or updated operating systems recently? Did this problem begin after windows installed new updates?
