Im trying to mount a micro-ATX mobo inside an ATX case. When I lay the mobo inside the ATX case, the cut outs in the case wall do not align with the connectors on the edge of the mobo. I am not even sure if the expansion slots in the mobo will align with the card slots in the case wall. Short of taking a Dremel saw and simply cutting out a large metal rectangle from the case wall to expose all mobo connectors, is there any way to adapt the ATX case to the micro-ATX mobo, or should I look for and buy another case that will allow a “drop in” fit where all the case cut outs align perfectly with the mobo connectors? (if such a case exists)?
