[SOLVED] how to arrange a ATX 24pin to Motherboard 2-port 6pin adapter Power supply cable
Kasmil
Commendable
May 31, 2019
8
i have an ATX 24pin to Motherboard 2-port 6pin adapter Power supply cable and it has a "GREEN,WHITE,RED AND BLACK". Can anyone tell me which wire is +12v, Gnd, and sense
Not sure why you need this, but I think I have this.....
Yellow is +12V. That's a given.
The purple is a +5VSB that gets converted to a +12VSB . That wire should go to a little lump in your cable harness wrapped in electrical tape.
Gray is PWR Good. Green is PWR ON. Blue is -12V.
Black is ground. Always ground.
So that tiny white plastic piece doesn't use pin 1 and 2. Pin 3 is PWR ON, 4 is PWR OK, 5 and 6 are both ground.
For the black 6-pin that looks like a PCIe connector but definitely IS NOT, pin 1 (lower left pin if looking at connector with latch on top) is ground, as is pin 2. Pin 3 is -12V. I'm REALLY curious what HP uses -12V for. Pin 4 and 5 is +12V. Pin 6 is the +12VSB from the little converter in the...
ATX-24pin-to-Motherboard-2-Port-6Pin-Adapter-18AWG-PSU-Power-Supply-Cable-Cord-for-HP.jpg_q50.jpg
For the black 6-pin that looks like a PCIe connector but definitely IS NOT, pin 1 (lower left pin if looking at connector with latch on top) is ground, as is pin 2. Pin 3 is -12V. I'm REALLY curious what HP uses -12V for. Pin 4 and 5 is +12V. Pin 6 is the +12VSB from the little converter in the electrical tape.
Oddly enough, there are NO sense wires used here.
EDIT: By the way, this will not fix your 515 error. The connector coming from the old PSU to the motherboard is not included in this adapter harness because a tachometer is not a normal function of a PSU fan (unless it's a digital PSU, but that's a whole other ball of wax). That was a completely separate connector from your old PSU.
You know... I've looked at a dozen pictures of these HP PSUs and boards and I can't figure out HOW the PSU reports fan RPM to the motherboard! There's no extra wire for it. The two open pins on that small, white 6-pin connector is NEVER populated, so it's not like they use one of those!
Really weird.
Do you still have the original HP power supply? Can you take a picture of all of the connector that come from it?
Hello, Did you solve this ?
I am thinking of buying the 800 g5 tower. But it will come with a 250w psu . I have a 4 years old 500w 24 pin psu . It can deliver 36A on the 12v rail . I use it on an old HP dx7400 ( that has standard 24pin psu originally) because a graphics card needed 20A on the 12V rail and the original psu delivered only 19A . ( I know the G5 800 tower 500w gives only 16A on the 12v rail)
What do i need to do buy in order to convert a 24pin psu into this strange motherboard ?
