How to ask for troubleshooting help V2
Proximon
Illustrious
The idea here is to help you organize your thoughts and communicate effectively. Remember, the more work you put into your post asking for help, the more likely we are to want to help you. 200 word paragraphs with no punctuation will not help your cause.
Even though I made this all look very regimented, we could care less if you follow this exact format. This is just to help you figure out what you need to say.
Step one: Title
Don't title your post "Help!" or "I'm Stuck!" because we already guessed that. Try to make your title attract the right person that will know how to help.
Examples:
No lights, no fans!
P5Q and Q6600 locks on post
Hard drive squeaks
Step two: The Opening
Make your first sentence or two a BRIEF STATEMENT of the problem. "My computer stopped working" is not helpful. "I can no longer see anything on my screen or hear any noises from my computer" is better.
Step three: History
When was the last time the computer worked right?
Was there something that happened right before things got bad?
Did you install some hardware?
Did you install some software?
Step four: The Full Story:
Tell us exactly what is happening.
This might include the sequence of sounds or lights when you press the power button. Careful observation on your part might well make the difference when old hands are figuring your problem out.
Write down error messages as they happen then include those. If the problem is a lock up, say what kind of lock up.
Is it just the program that locks?
Does the operating system lock up?
Step five: The specs
List each one of the parts in your computer. This must be a full list. If some parts are from an older build, this might be important.
CPU
Motherboard (model number)
RAM (Model number, speed, timings, voltage)
CPU cooler (stock or not, model if applicable)
Video Card (model number)
Power Supply (model number, or company and wattage at least)
Hard drive(s)
Operating System
Case (for cooling issues)
ANY other parts. If you have an ipod plugged in, we want to know.
Step six:
List all the steps you have taken to resolve this yourself. Number them. Why? Because we are probably going to dig back through your post looking for what you tried already... and if the thread goes on for a week that might be a lot of looking by a lot of people.
1.
2.
3.
Resources:
TH: READ before posting about boot problems!
Maximum PC on BSODs
Ultimate BIOS Guide: Every Setting Decrypted and Explained! -Maximum PC
This is a printable version.
Poor or No Electrical Ground - What to Do About It
HardwareLogic: My Computer Won't Start (DEAD)
CPU-Z Vital for overclocking, but also for detecting RAM settings.
Real Temp Just measures CPU core temps. Does it well.
HWMonitor Tracks many temps and a few other useful things.
Memtest86+ Useful for detecting faulty RAM, not so much incorrectly configured RAM.
Troubleshooting sleep mode issues in Vista
Where to buy a small motherboard speaker.
The Ultimate Boot CD When you need to boot from a CD to sort things out.
Aford10's guide to removing malware
This may not be a sticky, but it might be a useful tool. I would link an example of the unorganized and useless pleas for help we get every day, but that would be unkind and they are easy enough to find :p
xthekidx
Splendid
Dec 24, 2008
3,871
I think this probably fits under Step Four: Full Story
If your PC will not boot into Windows: Give a full play by play of what happens when you hit the power button. Do you get any lights? Fans spin? Video signal? Smoke and the smell of burning plastic (hopefully not!)? Beep error codes (this requires you to have a case speaker hooked up, which is a good idea regardless of whether you have issues with your PC or not)? Does the PC cycle the boot up process over and over, automatically shut itself down, just sit with fans spinning but nothing else, require you to shut down in an unconventional way (other than just holding down the power switch like having to switch off the PSU)? Make sure you give as many clues as you can so we can help you out. Don't leave out any details!
[that is pretty long and wordy, feel free to paraphrase :p]
kyeana
1,290
13
I would change step one from "Try to make your title attract a certain audience." to something more like "A brief description of the problem" or something along those lines
Proximon
Illustrious
That's brilliant, really. Thanks! Will update later.
WR2
Polypheme
A good title can help attract the people with the knowledge to fix your problem.
kyeana
1,290
13
Oh i completely agree, i just think the wording about attracting a certian audiance is bound to throw a few noobs off. I'm just suggesting something that would be easier for them to follow.
Kill@dor
663
I think if we there was a forum fillout form LOL...or some kind of drop down list of what they need help with before they post a thread would be sufficent. With all the stuff Prox listed of course...but a little less intimidating to our friendly geeks to be...
Just my 2 cents...
Proximon
Illustrious
Is it better now? and thanks for the help.
vdmerwe
Hi I have a boot problem that I just can't solve.
Simply...my mobo is booting seemingly perfectly.
-phase LEDs indicate a full CPU boot.
-all fans spin
-general 'hard-drive working' noises
However there is NO post, or recognisable graphical output to my monitor.
I've tried ALOT in isolating the problem, mainly in the CPU area, where I have mounted a back-panel for the HSF, but this has not solved anything, and makes me think the problem lies elsewhere.
Any ideas would be very much appreciated.
*full specs*
Corsair 4GB ddr2
[Force 3D]ATI Radeon 4670
Arctic 500W PSU
Gigabyte GA-EP43-DS3L/S3L mobo
Intel Core 2 Duo E7400 w/ Arctic Freezer Pro 7
drunknmunkys
346
Start your own thread and you'll get more help.
itsgrandpa
100
Similar issue as vdmerwe:
The build:
i7 920
asus p6t deluxe v2
902 antec case
OCZ 6GB ram
4870 vapor x 1gb
prolimatech megahelems
corsair 850HX psu
WD 1TB black
My computer was working great, had to install backplate for new CPU cooler. Plugged everything in correctly, now it won't start up...
The problem:
all the LED lights and all the fans turn on. But my computer fails to boot: the monitor doesn't turn on, nor does my mouse's red lazer light turn on.
I can use both the power button on the case and on the mobo "on" button to turn on the computer.
I haven't had a chance to play with the BIOS or overclock, so the computer is running on stock settings.
There is no beeping coming from the system.
I believe that its not a matter of the power, but since none of the output device's work... I think its the mobo. Why? i'm not sure but I would like to fix it regardless...
I'm afraid of the worst... any feedback would be really appreciated!!!
pctech2005
206
6
18,765
30
you changed out the motherboard. Unless it is the same as your old one, you will need to do a repair install of windows. You are in what I call boot loops which is due to the new hardware not matching the info in the hal.dll file of windows. A repair install should take care of this
Onyx3173
17
This might be a good place to put this tip since people with problems seem to read this topic. You might want to make sure your PSU has the right plugs. My current PC is my very first build and while I didn't think anything of it at the time, it was a 20-pin instead of a 20+4 pin PSU. All I paid attention to was the fact it was 600w which was more than powerful enough. I somehow managed to get it to start booting after fighting with it for almost a week but it doesn't actually feed enough power to your PC and causes data corruption. I don't know if anyone else had this sort of stupid but I hope this might help someone.
