How To Beat Mission 4: Checking out TF29 In Deus Ex: Mankind Divided
Now that your augments are all back online, it's time to report in for active duty again, by heading to the TF29s secret bunker.
Step 1)Ride the rails.
You'll need to take the subway to the Cista district, so take a look around near your apartment for the subway station. It's hard to miss with it's barbed wire fences and long line up of augs trying to get through. There is an entrance for naturals with no one waiting in line, which may be tempting to try and get through. You can if you like, but you'll get stopped and held up while they check your credentials. Head through the aug line and you can just run through the lines. Interact with the map for Palisade station and you'll set off on the train.
Step 2)Access the TF29 bunker
From the train station, head left to a shipping companies building called Praha Dovoz. This is the cover business for the task force, so head inside and to the back room. Check out the travel picture and you'll find you can move it aside to reveal a keycard swipe that you can use your access card to open this secret door and head on down to your base of operations.
Step 3)Access the NSN network's server room.
On the way down, you'll get a call from Alex to remind you to plant that whisper chip she gave you before the attack. The NSN server room is located on the second floor, but you'll need a keycard to open it. This keycard can be found in the IT server room, which is also locked. You have the option of either hacking the laptop beside the door for the passcode, hacking the door itself, or sneaking through the vent behind the stairs to drop into the IT room. Now that you have the keycard for the NSN server room, you can return to open the door, only to run into another locked door. You can hack this level 2 door, or, you can head down to the Cybercrime Office to find a Selina Carter's laptop that is only level 1 hacking. Once you've got access to the laptop it will provide you with the code to the door (which is 7734 if you want to just use it).
Step 4)Plant the whisper chip.
Now that you have full access to this server room, check the motherboard nearby. Open this up and insert the chip to get a call from Alex. She'll exclaim that someone is using the network right now, but Adam will cut her off when he gets called in to see Miller.
Step 5)Meet with Miller
If you look through the window in this server room, you'll see Miller getting out of the device that allows him to connect to the neural network. He doesn't sound happy when he calls for you to report in to him, so it's a good thing you're just next door. Head over to chat with him and you'll be assigned your next mission.
Once you have finished this mission, it's a good time to explore this base of operations fully. There are a lot of computers you can hack into to get a lot of interesting information, and plenty of goodies you can pick up as well. You can visit the firing range here as well to get a basic tutorial on your weapons and how to use the different ammunition and firing types for them, as well as how to modify them with spare parts.
