A new firmware up lets you use any USB device to boot a Raspberry Pi 4.
How to Boot Raspberry Pi 4 From a USB SSD or Flash Drive : Read more
I tried this as well and did not have the issue with my sdcard booting on RPI4 but the USB boot did not work and got same error on bootup.These instructions resulted in an error and also caused my pi to stop booting from the SD card.
When restarting after removing the SD card, I got an error on the bootloader screen saying:
Invalid ELF header: 'start_x.elf'
Firmware not found
And it would keep repeating and showing this error.
Then I tried reinserting my SD card and now it is showing the same error, even without the USB drive plugged in.
What has happened? I can't boot using my original SD card.
Yeah, I'm not sure why my sd card started getting the same error... Maybe I accidentally copied the bad start_x.elf to it or something. Anyway, I think there might be an issue with the current start_x.elf from the Github. Will wait for the OP's response.I tried this as well and did not have the issue with my sdcard booting on RPI4 but the USB boot did not work and got same error on bootup.
I'll do the same.Yeah, I'm not sure why my sd card started getting the same error... Maybe I accidentally copied the bad start_x.elf to it or something. Anyway, I think there might be an issue with the current start_x.elf from the Github. Will wait for the OP's response.
It already was before. This latest update doesn't make a huge difference, it just allows for the USB drive to completely replace the SD card. Previously the SD card was still required for the boot files and the root file system could be located on the USB drive.Any idea if this will enable the Raspberry Pi 4 to be a viable Plex Media Server?
Invalid ELF header: 'start_x.elf' Firmware not found
Firmware not found
This was my experience also when I tried yesterday. Then, last night (5-27-20) updated files were placed on github. Using those files, and following these directions, was successful. I can now boot either from microSD or from a Samsung EVO ssd drive through an adapter off the shelf from Best Buy.
Good luck!
Why are you doing this on an SD card. The instructions are for updating the *.dat and *.elf files ON THE USB DRIVE.These instructions resulted in an error and also caused my pi to stop booting from the SD card.
Firmware not found
Used it for PMS for a while. It depends on your client device - if it's a chromecast or Roku, you can expect 720p and 1080p if you're lucky (flaky 1080p support depends on codex supported). If you use Kodi you could probably use it more reliably as a PMS (so PI -> PI playback) but you might still get the occasional flaky support.Any idea if this will enable the Raspberry Pi 4 to be a viable Plex Media Server?
