How to build Powershot A85 Power supply?
G
Guest
Guest
Archived from groups: alt.comp.periphs.dcameras (More info?)
Has anyone built their own DC power supply for an A85? With four AA, it
would need to be 6 volt but what amperage?
What is the pin configuration, center + or -?
Thanks
"The Eye" <eyeonpoliticnospam@yahoo.com> wrote in message
news:wdCdnVLxiKs1SG7cRVn-oA@rcn.net...
> Thanks
Amperage is around 2-2.5 amps for digital cameras.
Why built one. You can buy regulated power adapters for $20-30.
Here is a universal ac adapter for Digital Cameras. About $30.
http://www.digipowersolutions.com/show_product.php3?pid=100817&Group=AC+Adaptors&Type=A80&Manuf=CANON&subgroup=
Radio Shack has one(if you can find it):
Catalog #: 273-1696
http://www.radioshack.com/searchsku.asp?find=273-1696
CSM1
http://www.carlmcmillan.com
Would that one work on a powershot a400?
I already have an adapter with a ton of jacks, it says right on the adapter
what the voltage levels can be set at (multiple levels) but how could I tell
if it'd provide the right amperage? I'm not super-knowledgable about
electrical circuitry, just enough to know that there is more to a given
source of DC than voltage (pressure of electrons) but also amperage(volume
of electrons at a given voltage).
Any informed opinions gratefully accepted.
"CSM1" <nomoremail@nomail.com> wrote in message
news:EERId.18850$wi2.6977@newssvr11.news.prodigy.com...
>> Thanks
> Catalog #: 273-1696
> CSM1
If the power adapter can supply up to about 2 amperes of current and is
voltage regulated for the voltage that is set, then it is safe to use on
just about any digital still camera. (you just have to find the power plug
that fits and has the correct polarity)
DO NOT use a power adapter that is NOT regulated.
The camera will only draw as much current as needed. A power supply with a
larger current capacity is necessary over a power supply that does not have
enough current capacity.
If the power supply does not have enough power (current), the voltage will
drop to a level too low for the camera to work correctly.
By the way there is another universal power adapter.
http://www.bizrate.com/buy/products__att259--221062-,cat_id--46011.html
The important things to know about power for digital cameras is Voltage,
Current and Polarity.
Volt defined:
The volt is the practical unit of electromotive force (emf), or electric
potential. It is that potential which will cause a current of one ampere to
flow through a resistance of one ohm.
CSM1
"Tom" <cyberhun@shaw.ca> wrote in message
news:aqTId.152141$Xk.123613@pd7tw3no...
> adapter what the voltage levels can be set at (multiple levels) but how
> could I tell if it'd provide the right amperage? I'm not
> super-knowledgable about electrical circuitry, just enough to know that
> there is more to a given source of DC than voltage (pressure of electrons)
> but also amperage(volume of electrons at a given voltage).
>>> it would need to be 6 volt but what amperage?
>>> Thanks
>> Catalog #: 273-1696
>> CSM1
Hah! I finally found it. OK, on it it says ---
PLUG-IN CLASS 2 TRANSFORMER
"MW Switching Universal Power Supply", made in China, and a Canadian
Underwriters Lab Symbol
Model MWS1189UC
Input 100V-140V, AC 60Hz, 28W
Output: 3, 4.5, 6, 7.5, 9, 12v DC.
Current 1700 mA
-I have a voltmeter and I tested some NiMH batteries that were rated at 1.2V
(much to my surprise, I had assumed they were 1.5V, but I got home and
looked at the package and it said 1.2V) right after I finished charging
them, and they were in fact, only putting out 1.2V when hooked up to the
large resistance associated with a voltmeter, when they were connected to an
actual load of much lower resistance, I'm sure their V would be even
less --- my point in all this being that even if my adapter is rated at
1700mAh, don't you think the camera could handle it anyway (especially if I
turned the LCD screen brightness way down) because it clearly can handle
batteries that put out significantly less than 1.5V? (sorry, long question)
-Does the fact that this adapter states a current at all, indicate that it
is 'Regulated'?
-A lot of these NiMH batteries have ratings like 300mAh, or the highest I
think was 2300mAh --- does this kind of rating mean basicaly that for the
first hour of use, at the rated voltage of 1.5V, they put out that average
amount of current (because it would vary, wouldn't it, somewhat anyway as
the battery depleted itself)?
-If a NiMH battery was rated at 300mAh does that mean it puts out an average
of 300mA/hour at the rated voltage of 1.5V, over it's lifetime?
"tom" <cyberhun@shaw.ca> wrote in message
news:fYYId.154987$8l.139015@pd7tw1no...
> Model MWS1189UC
> Current 1700 mA
1.2V
an
I
question)
> is 'Regulated'?
average
The Adapter may or may not be regulated, If it does not say I would test the
adapter before using it on my digital camera.
Select 6 volts, measure the power supply without a load (leads open), note
the voltage (it must be 6 volts +- 5%).
To put a 1700 mA load at 6 volts you would need a 35.29 ohm resistor, but
since the closest standard value is 36 ohms, use a 36 ohm, one watt or more
resistor. The resistor will get very warm (hot to the touch). Put power
supply and the volt meter across the resistor to see if the voltage stays at
6 volts. If the voltage does not drop more than 5%, it is regulated and safe
to use on a digital camera. (5% drop from 6 volts = 5.7 volts)
However 1700 ma is very close to the minimum current capacity for supplying
a digital camera. Not using the LCD will conserve the most power. If there
is an optical viewfinder, use that to frame the picture. Be conservative
with flash use also.
On NiMH batteries, when fully charged the voltage is about 1.3-1.4 volts no
load.
Nominal voltage is 1.25 volts. (they get better with some use)
The MaH rating is based on supplying the rated current for one hour before
dropping to some stated minimum voltage (around 1 volt).
A fully charged 300 mah battery with supply 300 ma for one hour until the
voltage is around 1 volt. (It would keep outputting some current until the
battery is dead). Digital Cameras have a power protection built-in that
shuts down the camera at some minimum voltage.
You want the highest Mah rating you can find for the best price. The higher
the Mah the longer the batteries will operate the camera. For Digital
cameras, the minimum I would use is 1600 Mah.
CSM1
I must not be understanding something properly (please be patient, I'm not
very technicaly oriented ).:
-if a battery rated at 300mAh only provides 300mA, how is it possible for a
300mAh to power one of these cameras at all? Given that the camera needs
minimun 1700mA( I thought that was what you said, no? Different context
maybe), and the battery only puts out 300mA? Yet it has been my experience
that these 300mAh batteries will run a digital camera, just not for very
long.
news:0NaJd.23946$iC4.15230@newssvr30.news.prodigy.com...
>> Model MWS1189UC
>> Current 1700 mA
> 1.2V
> an
> I
> question)
>> it
>> is 'Regulated'?
>> average
> average
> the
> more
> at
> safe
> supplying
> no
> load.
> higher
> CSM1
I made a big miscalculation on the resistor needed to test the power
adapter. I said one watt, but the correct wattage is 10 watts. The
resistance is 6/1.7=3.529 ohms.
(1700 ma=1.7 A)
For a 10 watt wire wound resistor the nearest standard value is 4 ohms, so 6
V/4 ohms=1.5 or 1500 ma. 6 volts times 1.5 A = 9 watts.
CSM1
> > Model MWS1189UC
> > Current 1700 mA
> 1.2V
to
> an
if
> I
> question)
it
> > is 'Regulated'?
I
the
average
as
> average
the
more
at
safe
supplying
no
> load.
higher
> CSM1
Question: Will a 300 mah battery power a digital camera?
The short answer is not for very long. A 300 mah battery will supply 1700 ma
for a very short time. About 10-11 minutes.
As long as the voltage is present, the load will draw as much current as
demanded. If the camera looks like a 3.5 ohm resistor to the 6 volt battery,
the battery will try to supply 1700 ma. (It is Ohms law) Ohms law is voltage
divided by resistance in ohms equals current in amps. E/R=I where E is
Voltage, R is resistance in ohms and I is current in amps.
What happens with batteries, the voltage drops with the more load put on it.
You would not want to put a short on a strong battery, such as your car
battery, it will explode.
Use 1600 mah or more. A 1600 mah battery will supply 1600 ma for one hour
until the battery voltage drops to around 1 volt. 1600 ma = 1.6 amperes.
A 2300 mah battery = 2.3 amperes for one hour. At 1700 ma load, it will last
longer.
I miscalculated the resistor to test the power adapter. Use a 4 ohm 10 watt
wire wound resistor.
CSM1
news:cfbJd.160009$6l.43964@pd7tw2no...
a
experience
> long.
> >> Model MWS1189UC
> >> Current 1700 mA
> > 1.2V
the
to
> > an
if
> > I
handle
> > question)
> >> it
> >> is 'Regulated'?
I
the
> >> average
as
> > average
> > the
note
but
> > more
stays
> > at
> > safe
> > supplying
there
> > no
> > load.
before
the
the
> > higher
> > CSM1
OK, I'm going to try to dig up a 4ohm resistor. Would you verify the color
codes?
I believe for a 4 Ohm resistor, the bands would be yellow, black, gold,
brown. with the last band indicating tolerance, not that critical in this
case.
I don't even know if I've got one, but are those the right bands --- CSM1?
news:HhbJd.19177$wi2.11806@newssvr11.news.prodigy.com...
> (1700 ma=1.7 A)
> 6
> CSM1
>> > Model MWS1189UC
>> > Current 1700 mA
>> 1.2V
>> > the
> to
>> an
> if
>> I
>> > handle
>> question)
> it
>> > is 'Regulated'?
> I
> the
> average
> as
>> average
> the
>> note
> more
> at
> safe
> supplying
>> there
> no
>> load.
>> before
>> the
> higher
>> CSM1
You made me think, it has been a long time since I read color codes.
Black Yellow Black
1st band Color is on one end of the resistor. Read Left to Right.
First significant figure Black is 0
Second significant figureYellow is 4
Multiplier Black is 1
Fourth band is tolerance.
Gold = 5%
Silver=10%
No color= 20%
Values of less that one ohm then use the multiplier of Gold = 0.1 and
Silver=0.01. Which is Gold divide by 10 or Silver divide by 100.
10 Watt wire wound resistors usually do not have color codes. The value is
printed on the light brown square.
CSM1
news:OSdJd.160478$Xk.128769@pd7tw3no...
> color codes?
> case.
>> (1700 ma=1.7 A)
>> so 6
>> CSM1
>>> > Model MWS1189UC
>>> > Current 1700 mA
>>> > at
>>> 1.2V
>>> > charging
>>> > the
>> to
>>> an
>>> > at
>> if
>>> I
>>> > handle
>>> question)
>>> > that
>> it
>>> > is 'Regulated'?
>>> > highest
>> I
>> the
>> average
>> as
>>> average
>> the
>>> note
>>> but
>> more
>>> stays
>> at
>> safe
>> supplying
>>> there
>> no
>>> load.
>>> before
>>> the
>>> the
>> higher
>>> CSM1
There are no bands on a 10W resistor. The rating is printed on the side or
top.
If you require 10 Watts if actual power, a 25W resistor would last much
longer, not burn up as quickly, disapate the heat better (run cooler to the
touch). Yes a 10W resistor is capable of disapating 10watts but only at it's
maximum rated temperature that will burn you if you touch it.
Remember that the power is proportional to the square of the appplied
voltage and even a slight voltage fluctuation can push the power over the
rating quite easily.
news:h6gJd.24007$iC4.7314@newssvr30.news.prodigy.com...
> Black Yellow Black
> Gold = 5%
> Silver=10%
> No color= 20%
is
> CSM1
> > color codes?
this
> > case.
CSM1?
> >> (1700 ma=1.7 A)
> >> so 6
> >> CSM1
> >>> > Model MWS1189UC
> >>> > Current 1700 mA
> >>> > at
> >>> 1.2V
and
> >>> > charging
> >>> > the
connected
> >> to
> >>> an
> >>> > at
(especially
> >> if
> >>> I
> >>> > handle
> >>> question)
> >>> > that
> >> it
> >>> > is 'Regulated'?
> >>> > highest
> >> I
for
> >> the
> >> average
anyway
> >> as
> >>> average
test
> >> the
> >>> note
> >>> but
> >> more
power
> >>> stays
> >> at
and
> >> safe
> >> supplying
> >>> there
conservative
volts
> >> no
> >>> load.
> >>> before
> >>> the
> >>> the
that
> >> higher
> >>> CSM1
I have a 4.7 ohm 2 watt resistor.
The color bands are yellow,violet,gold.
So the bands for 4 ohms would be yellow, black,gold.
Or they could be black,yellow,black.
CSM1
color
> codes?
> case.
> > (1700 ma=1.7 A)
so
> > 6
> > CSM1
> >> > Model MWS1189UC
> >> > Current 1700 mA
at
> >> 1.2V
and
charging
> >> > the
connected
> > to
> >> an
at
(especially
> > if
> >> I
> >> > handle
> >> question)
that
> > it
> >> > is 'Regulated'?
highest
> > I
> > the
> > average
anyway
> > as
> >> average
test
> > the
> >> note
but
> > more
stays
> > at
> > safe
> > supplying
> >> there
conservative
volts
> > no
> >> load.
> >> before
the
> >> the
> > higher
> >> CSM1
Black, yellow, black isn't used in standard colour codes
news:JrgJd.19308$wi2.2137@newssvr11.news.prodigy.com...
> CSM1
> color
> > codes?
this
> > case.
CSM1?
> > > (1700 ma=1.7 A)
ohms,
> so
> > > 6
> > > CSM1
Canadian
> > >> > Model MWS1189UC
> > >> > Current 1700 mA
rated
> at
> > >> 1.2V
> and
> charging
to
> > >> > the
> connected
> > > to
> > >> an
even
rated
> at
> (especially
> > > if
> > >> I
> > >> > handle
> > >> question)
> that
> > > it
> > >> > is 'Regulated'?
> highest
> > > I
for
> > > the
> > > average
> anyway
> > > as
an
> > >> average
> test
> > > the
> > >> note
> but
or
> > > more
power
> stays
> > > at
and
> > > safe
> > > supplying
> > >> there
> conservative
> volts
> > > no
> > >> load.
> > >> before
> the
until
> > >> the
that
> > > higher
> > >> CSM1
It has been years, I did not remember that the Gold and Silver multiplier is
used below 10 ohms. I though it was one ohm.
CSM1
"Gymmy Bob" <nothanksx@bite.me> wrote in message
news:idydnY4SXqGWCmjcRVn-sg@golden.net...
> > CSM1
> > color
> > > codes?
gold,
> this
> > > case.
> CSM1?
> > > > (1700 ma=1.7 A)
> ohms,
> > so
> > > > 6
> > > > CSM1
> Canadian
> > > >> > Model MWS1189UC
> > > >> > Current 1700 mA
> rated
> > at
> > > >> 1.2V
home
> > and
> > charging
> to
> > > >> > the
> > connected
> > > > to
> > > >> an
> even
> rated
> > at
> > (especially
> > > > if
> > > >> I
> > > >> > handle
long
> > > >> question)
indicate
> > that
> > > > it
> > > >> > is 'Regulated'?
> > highest
> > > > I
> for
> > > > the
that
> > > > average
> > anyway
> > > > as
> an
> > > >> average
> > test
> > > > the
open),
> > > >> note
resistor,
> > but
> or
> > > > more
> power
> > stays
> > > > at
> and
> > > > safe
> > > > supplying
If
> > > >> there
> > conservative
> > volts
> > > > no
> > > >> load.
> > > >> before
until
> > the
> until
> > > >> the
> that
The
> > > > higher
Digital
> > > >> CSM1
Precision resirtors are printed text on the side. I believe precision
resistors can be ordered custom made or from a big supplier in any value
desired for not too bad a price (a few years back). The time wait for them
is brutal though.
news:btiJd.24026$iC4.15242@newssvr30.news.prodigy.com...
is
> CSM1
> > > CSM1
the
> > > color
> > > > codes?
> gold,
in
> > this
> > > > case.
> > CSM1?
power
> > > > > (1700 ma=1.7 A)
> > ohms,
> > > so
> > > > > 6
> > > > > CSM1
> > Canadian
> > > > >> > Model MWS1189UC
> > > > >> > Current 1700 mA
> > rated
> > > at
> > > > >> 1.2V
> home
> > > and
> > > charging
up
> > to
> > > > >> > the
> > > connected
> > > > > to
> > > > >> an
> > even
> > rated
> > > at
> > > (especially
> > > > > if
> > > > >> I
can
> > > > >> > handle
> long
> > > > >> question)
> indicate
> > > that
> > > > > it
> > > > >> > is 'Regulated'?
> > > highest
> > > > > I
that
> > for
> > > > > the
> that
> > > > > average
> > > anyway
> > > > > as
out
> > an
> > > > >> average
would
> > > test
> > > > > the
> open),
> > > > >> note
> resistor,
> > > but
watt
> > or
> > > > > more
> > power
voltage
> > > stays
> > > > > at
regulated
> > and
> > > > > safe
> > > > > supplying
> If
> > > > >> there
> > > conservative
1.3-1.4
> > > volts
> > > > > no
> > > > >> load.
hour
> > > > >> before
> until
> > > the
> > until
> > > > >> the
built-in
> > that
> The
> > > > > higher
> Digital
> > > > >> CSM1
Ok, well it looks good, actually. I found a resistor that didn't have color
bands on it, but was red, and had 4R(7 or Z couldn't tell), and +-5% on the
other side. Since it is only necessary to hook it up momentarily to a low
voltage I wasn't that worried about heat dissipation capacity.
I checked the R with my multimetere and it showed exactly 4 Ohms of
resistance.
Then I set the adapter at 3V, with no load but the meter, and tested --- it
showed exactly 3V, to within a hair actually.
Then I put the resistor in parallel with the meter and it showed exactly the
same voltage, no perceptible drop. And I know I had good connection with
the resistor becaue, boy, did it ever get hot --- in the two seconds that
power was applied, it got too hot to touch and I could smell the 'hot
component' smell! No smoke, but next time I do something like this I'll pay
more attention to power ratings, I think.
So there doesn't seem to be a problem with the adapter supplying enough amps
to a the camera, is there any way to ensure it won't push too much?
No, I guess not because you said that the camera will only take what it
needs, right? The only potential problem was that it couldn't supply ENOUGH
amps, and the voltage would sag(if I have it right), if it wasn't regulated.
Now there's another problem with using this adapter, which is that not one,
out of the dozen or so jacks that came with the adapter, fits the DC In
receptacle on the camera. I'll go hunt around 2nd hand shops and see what I
can find.
How's my methodology here, guys? Am I making any glaring mistakes?
news:BaqdnTo-ALbsKWjcRVn-pg@golden.net...
> is brutal though.
> is
>> CSM1
>> > > CSM1
> the
>> > > color
>> > > > codes?
>> gold,
> in
>> > this
>> > > > case.
>> > > > bands ---
>> > CSM1?
> power
>> > > > > The
>> > > > > (1700 ma=1.7 A)
>> > ohms,
>> > > so
>> > > > > 6
>> > > > > CSM1
>> > Canadian
>> > > > >> > Model MWS1189UC
>> > > > >> > Current 1700 mA
>> > rated
>> > > at
>> > > > >> 1.2V
>> home
>> > > and
>> > > charging
> up
>> > to
>> > > > >> > the
>> > > connected
>> > > > > to
>> > > > >> an
>> > > > >> > be
>> > even
>> > rated
>> > > at
>> > > (especially
>> > > > > if
>> > > > >> I
> can
>> > > > >> > handle
>> long
>> > > > >> question)
>> indicate
>> > > that
>> > > > > it
>> > > > >> > is 'Regulated'?
>> > > > >> > the
>> > > highest
>> > > > > I
> that
>> > for
>> > > > > the
>> that
>> > > > > average
>> > > > >> > somewhat
>> > > anyway
>> > > > > as
> out
>> > an
>> > > > >> average
>> > > > >> > lifetime?
> would
>> > > test
>> > > > > the
>> open),
>> > > > >> note
>> resistor,
>> > > but
> watt
>> > or
>> > > > > more
>> > > > >> Put
>> > power
> voltage
>> > > stays
>> > > > > at
> regulated
>> > and
>> > > > > safe
>> > > > >> for
>> > > > > supplying
>> > > > >> power.
>> If
>> > > > >> there
>> > > conservative
> 1.3-1.4
>> > > volts
>> > > > > no
>> > > > >> load.
> hour
>> > > > >> before
>> until
>> > > the
>> > until
>> > > > >> the
> built-in
>> > that
>> The
>> > > > > higher
>> Digital
>> > > > >> CSM1
That was probably a good enough test.
Since the voltage did not change from no load to half full load, the power
supply is regulated.
The next most important thing is to get the polarity correct.
Look closely at the symbol next to the power connector on the camera, it
should have the polarity marked.
Use a magnifying glass to see the + or - symbol in the center of the
semicircle.
Wire a connector to the power supply that fits the camera. Make sure the
polarity is correct for the center connector of the plug.
Put the power supply on 3 volts and DO NOT change to any other voltage.
The A400 uses 2 AA batteries, so the voltage required is 3 volts.
It would be a good idea to put tape on the voltage switch, so that it does
not get changed accidentally.
Be brave, try it on the camera.
If you want to buy the ACK 800 AC adapter kit, click this link. I have seen
it for $30 at amazon.com.
http://www.google.com/froogle?q=AC+adapter+kit+ACK800+&btnG=Search+Froogle
CSM1
news:WEjJd.163793$8l.10981@pd7tw1no...
color
the
> resistance.
it
the
pay
amps
ENOUGH
regulated.
one,
I
> can find.
them
> > is brutal though.
multiplier
> > is
> >> CSM1
> >> > > CSM1
> > the
> >> > > color
> >> > > > codes?
> >> gold,
critical
> > in
> >> > this
> >> > > > case.
> >> > > > bands ---
> >> > CSM1?
> > power
> >> > > > > The
> >> > > > > (1700 ma=1.7 A)
4
> >> > ohms,
> >> > > so
> >> > > > > 6
> >> > > > > CSM1
> >> > Canadian
> >> > > > >> > Model MWS1189UC
> >> > > > >> > Current 1700 mA
were
> >> > rated
> >> > > at
> >> > > > >> 1.2V
got
> >> home
> >> > > and
finished
> >> > > charging
hooked
> > up
> >> > to
> >> > > > >> > the
> >> > > connected
> >> > > > > to
> >> > > > >> an
> >> > > > >> > be
> >> > even
is
> >> > rated
> >> > > at
> >> > > (especially
> >> > > > > if
> >> > > > >> I
clearly
> > can
> >> > > > >> > handle
(sorry,
> >> long
> >> > > > >> question)
> >> indicate
> >> > > that
> >> > > > > it
> >> > > > >> > is 'Regulated'?
> >> > > > >> > the
> >> > > highest
> >> > > > > I
> > that
> >> > for
> >> > > > > the
out
> >> that
> >> > > > > average
> >> > > > >> > somewhat
> >> > > anyway
> >> > > > > as
puts
> > out
> >> > an
> >> > > > >> average
> >> > > > >> > lifetime?
> > would
> >> > > test
> >> > > > > the
> >> open),
> >> > > > >> note
> >> resistor,
> >> > > but
> > watt
> >> > or
> >> > > > > more
> >> > > > >> Put
> >> > power
> > voltage
> >> > > stays
> >> > > > > at
> > regulated
> >> > and
> >> > > > > safe
> >> > > > >> for
> >> > > > > supplying
> >> > > > >> power.
> >> If
> >> > > > >> there
> >> > > conservative
> > 1.3-1.4
> >> > > volts
> >> > > > > no
> >> > > > >> load.
> > hour
> >> > > > >> before
hour
> >> until
> >> > > the
current
> >> > until
> >> > > > >> the
> > built-in
> >> > that
price.
> >> The
> >> > > > > higher
> >> Digital
> >> > > > >> CSM1
There is no polarity switch, you alter the plug's polarity by how the plug
connects to the cord, it has 2 identical prongs that go into 2 identical
receptacles and depending on which prong goes into which hole the polarity
of the plug is determined --- point taken, though. I'll tape it.
So, if it goes bang and fills the room with evil plastic-smelling fumes,
you'll buy me another one, right?
(joke)
I'll let you know what happens, but first I have to find a plug.
news:KDtJd.19532$wi2.19404@newssvr11.news.prodigy.com...
> semicircle.
> seen
> CSM1
> color
> the
>> low
>> resistance.
> it
> the
> pay
> amps
> ENOUGH
> regulated.
> one,
>> what
> I
>> can find.
>> > value
> them
>> > is brutal though.
> multiplier
>> > is
>> >> CSM1
>> >> > > CSM1
>> >> > > > verify
>> > the
>> >> > > color
>> >> > > > codes?
>> >> > > > black,
>> >> gold,
> critical
>> > in
>> >> > this
>> >> > > > case.
>> >> > > > bands ---
>> >> > CSM1?
>> > power
>> >> > > > > The
>> >> > > > > (1700 ma=1.7 A)
>> >> > > > > is
> 4
>> >> > ohms,
>> >> > > so
>> >> > > > > 6
>> >> > > > > CSM1
>> >> > Canadian
>> >> > > > >> > Model MWS1189UC
>> >> > > > >> > Current 1700 mA
> were
>> >> > rated
>> >> > > at
>> >> > > > >> 1.2V
> got
>> >> home
>> >> > > and
> finished
>> >> > > charging
> hooked
>> > up
>> >> > to
>> >> > > > >> > the
>> >> > > > >> > were
>> >> > > connected
>> >> > > > > to
>> >> > > > >> an
>> >> > > > >> > would
>> >> > > > >> > be
>> >> > even
> is
>> >> > rated
>> >> > > at
>> >> > > (especially
>> >> > > > > if
>> >> > > > >> I
> clearly
>> > can
>> >> > > > >> > handle
> (sorry,
>> >> long
>> >> > > > >> question)
>> >> indicate
>> >> > > that
>> >> > > > > it
>> >> > > > >> > is 'Regulated'?
>> >> > > > >> > the
>> >> > > highest
>> >> > > > > I
>> >> > > > >> > basicaly
>> > that
>> >> > for
>> >> > > > > the
> out
>> >> that
>> >> > > > > average
>> >> > > > >> > somewhat
>> >> > > anyway
>> >> > > > > as
> puts
>> > out
>> >> > an
>> >> > > > >> average
>> >> > > > >> > lifetime?
>> > would
>> >> > > test
>> >> > > > > the
>> >> > > > >> (leads
>> >> open),
>> >> > > > >> note
>> >> resistor,
>> >> > > but
>> >> > > > >> one
>> > watt
>> >> > or
>> >> > > > > more
>> >> > > > >> Put
>> >> > power
>> > voltage
>> >> > > stays
>> >> > > > > at
>> > regulated
>> >> > and
>> >> > > > > safe
>> >> > > > >> volts)
>> >> > > > >> for
>> >> > > > > supplying
>> >> > > > >> power.
>> >> If
>> >> > > > >> there
>> >> > > conservative
>> > 1.3-1.4
>> >> > > volts
>> >> > > > > no
>> >> > > > >> load.
>> >> > > > >> use)
>> >> > > > >> one
>> > hour
>> >> > > > >> before
> hour
>> >> until
>> >> > > the
> current
>> >> > until
>> >> > > > >> the
>> > built-in
>> >> > that
> price.
>> >> The
>> >> > > > > higher
>> >> Digital
>> >> > > > >> CSM1
"4R7" is the standard way of rating resistors in ohms. Back in about 1976
the standards committees decided to replace the decimal point with "R" to
make diagrams and components more readable. "K" replaces "kilo" and "M"
replaces "Mega" etc...
4K7 would be 4700 ohms and 3M125 would be 3.125 megohms.
color
the
> resistance.
it
the
pay
amps
ENOUGH
regulated.
one,
I
> can find.
them
> > is brutal though.
multiplier
> > is
> >> CSM1
> >> > > CSM1
> > the
> >> > > color
> >> > > > codes?
> >> gold,
critical
> > in
> >> > this
> >> > > > case.
> >> > > > bands ---
> >> > CSM1?
> > power
> >> > > > > The
> >> > > > > (1700 ma=1.7 A)
4
> >> > ohms,
> >> > > so
> >> > > > > 6
> >> > > > > CSM1
> >> > Canadian
> >> > > > >> > Model MWS1189UC
> >> > > > >> > Current 1700 mA
were
> >> > rated
> >> > > at
> >> > > > >> 1.2V
got
> >> home
> >> > > and
finished
> >> > > charging
hooked
> > up
> >> > to
> >> > > > >> > the
> >> > > connected
> >> > > > > to
> >> > > > >> an
> >> > > > >> > be
> >> > even
is
> >> > rated
> >> > > at
> >> > > (especially
> >> > > > > if
> >> > > > >> I
clearly
> > can
> >> > > > >> > handle
(sorry,
> >> long
> >> > > > >> question)
> >> indicate
> >> > > that
> >> > > > > it
> >> > > > >> > is 'Regulated'?
> >> > > > >> > the
> >> > > highest
> >> > > > > I
> > that
> >> > for
> >> > > > > the
out
> >> that
> >> > > > > average
> >> > > > >> > somewhat
> >> > > anyway
> >> > > > > as
puts
> > out
> >> > an
> >> > > > >> average
> >> > > > >> > lifetime?
> > would
> >> > > test
> >> > > > > the
> >> open),
> >> > > > >> note
> >> resistor,
> >> > > but
> > watt
> >> > or
> >> > > > > more
> >> > > > >> Put
> >> > power
> > voltage
> >> > > stays
> >> > > > > at
> > regulated
> >> > and
> >> > > > > safe
> >> > > > >> for
> >> > > > > supplying
> >> > > > >> power.
> >> If
> >> > > > >> there
> >> > > conservative
> > 1.3-1.4
> >> > > volts
> >> > > > > no
> >> > > > >> load.
> > hour
> >> > > > >> before
hour
> >> until
> >> > > the
current
> >> > until
> >> > > > >> the
> > built-in
> >> > that
price.
> >> The
> >> > > > > higher
> >> Digital
> >> > > > >> CSM1
Put a load of 1/4th that of your device and measure the voltage. rplace with
the device and measure. If they're equal - it's regulated!
No other way? I don't have a voltmeter.......
Plug your camera in and if you get smoke, the power supply is not regulated.
You take a big risk, not knowing.
The label will say regulated or stabilized if it is. If the label does not
say, it probably is not.
Take the power supply to a electronic repair shop (TV shop) and have the
tech check it.
CSM1
"some guy" <nospam@spam.com> wrote in message
news:37emq2F5ceuipU1@individual.net...
with
Not really true about the regulated. Most won't say since they are OEM
specific.
news:OqvQd.47370$iC4.8881@newssvr30.news.prodigy.com...
regulated.
> tech check it.
> CSM1
rplace
> with
